Newb Here. Question regarding rolling rear auto locks
RE: Newb Here. Question regarding rolling rear auto locks
welcome to df, are u talking antilock breaks?? if so u can "turn off" them by unpluging the sensor to each wheel... but with that u will get a abs light on ur dash display.... hope i helped, and if not post again once again welcome to DF
The locks are activated by whats called the speed sense wire which is hooked up to the module under your dash. Im not sure iuf you can disable that feature but you can get an aftermarket alarm and have the doors all unlock when you turn off the key!! Just an option
Trending Topics
ORIGINAL: Caraudioholic24
https://dodgeforum.com/m_1378750/tm.htm
on mine it locks all four doors, but when you pull the handle on any door from the inside it unlocks. without haveing to pull the lock up by hand. I dont see it as a prob in any way.lol Especially in some of the areas I have to drive through in phoenix. Wouldnt want someone snatching the door open and jacking my car at light. lol
