Synthetic motor oils
Old Sep 14, 2008 | 08:46 AM
ronnie22's Avatar
ronnie22
Default Synthetic motor oils
I'm thinking about changing my oil to synthetic, is it a good idea?
2004 RT
Old Sep 14, 2008 | 10:19 AM
bone33's Avatar
bone33
i dont use it.
heres a link with all the answers in the whole world. https://dodgeforum.com/forum/search.php?searchid=94716
Old Sep 14, 2008 | 02:02 PM
smallblockfreak's Avatar
smallblockfreak
Brad-Penn FTW
Old Sep 14, 2008 | 08:52 PM
bone33's Avatar
bone33
Originally Posted by smallblockfreak
Brad-Penn FTW
only true rednecks like you and me know about that stuff. i like how its green, thats cool.
Old Sep 14, 2008 | 10:44 PM
darthroush's Avatar
darthroush
Section Moderator
Depends on several things if it is worth it or not.
Old Sep 15, 2008 | 01:06 AM
N30N's Avatar
N30N
its better and more pure, and if your hard on your car it will help alot...but im not debate-ing this cause it will go on forever.
just my 2 cents
Old Sep 15, 2008 | 03:20 AM
Exubus's Avatar
Exubus
Brad-Penn FTW
+1... pricey but worth it.
Other good oils (synthetics), in this order:
Redline
Pennzoil Platinum
AMSOil
Mobil1
Royal Purple
If your car has over 70k miles on it or so, and do a lot of short-distance driving, I suggest you do some research before you go full synthetic. Running conventional oil under heavier driving conditions for a long time, then switching to synthetic can cause your seals/gaskets to start leaking, etc. Research it a bit more and you'll find much more detailed explanations of why.
However if the above does not apply to you, then using synthetic is a great choice for many reasons.
Old Sep 15, 2008 | 03:23 AM
N30N's Avatar
N30N
Mobil 1-hell yea
(good S***)
Old Sep 15, 2008 | 12:52 PM
darthroush's Avatar
darthroush
Section Moderator
Redline
Pennzoil Platinum
AMSOil
Mobil1
Royal Purple
Simply put, they clean better and can loosen gunk up that has kept a seal/gasket from leaking. There is more to it though.
On mine, because it had a small leak when I bought it, I am just going to stick with Valvoline 5W-30 Synthetic Blend High Mileage. Get a bit of synthetic oil and some extra seal/gasket conditioners too. Wal-Mart has the 5 quart container for $14.
As for full Synthetic, Royal Purple for me!
Old Sep 15, 2008 | 11:31 PM
N30N's Avatar
N30N
RP is the best but why???
anyone really know
