03 sx 2.0 starting problem
Old Oct 1, 2008 | 10:35 PM
zakman1997's Avatar
zakman1997
Default 03 sx 2.0 starting problem
I have an 03 dodge sx 2.0 (neon) and it is not starting. When I turn the key all the lights go on but it won't turn over. I have already replaced the battery as that is what some friends told the problem was but it is still happening.
Old Oct 1, 2008 | 10:55 PM
srtgtr34's Avatar
srtgtr34
Make sure all your grounds are connected. Do you hear clicking when your trying to turn the engine over?
Old Oct 1, 2008 | 11:17 PM
zakman1997's Avatar
zakman1997
it will not turn over.
Old Oct 2, 2008 | 10:29 AM
mjs182004's Avatar
mjs182004
check all you fuses under the hood, this happened to me also. i can't remember which fuse it is so just check them all. i believe its a 20 amp fuse. this should fix the problem.
Old Oct 2, 2008 | 08:02 PM
zakman1997's Avatar
zakman1997
I check very fuse under the hood and in the dash and they all look ok.
Old Oct 2, 2008 | 08:11 PM
Adionik's Avatar
Adionik
Check the starter?
Old Oct 3, 2008 | 02:10 AM
mjs182004's Avatar
mjs182004
when you try to start it does a solid red light that is in a shape of a circle come on the right hand side or the dash and stay on? if so then your key needs may possibly need to be reprogrammed. thats kind of a long shot but might be the security issue if you have a sentry key. but i still think it could be a fuse. sometimes they may look ok but in fact are not.
Old Oct 10, 2008 | 01:28 AM
zakman1997's Avatar
zakman1997
just to let everyone know that it was the ignition switch.
Old Oct 10, 2008 | 03:27 AM
Caraudioholic24's Avatar
Caraudioholic24
wow that was gonna be my next guess. That happened to me on my dodge daytona. Messed me up for a week till i traced every wire and found it too was the ignition switch. LOL good job hope it didnt cost you an arm and a leg!!
