so when i first boosted my car i used platinum plugs(few heat ranges lower) and still stock wires. Then after a while a friend told me to use copper plugs with boost bc something to do with detonation. Well now the car is startin to studder when it gets into boost like the plugs are missing and need changed. Im also going to upgrade wires, just like to know what you would recommend for plugs and wires
Since the Granatelli wires seem to not work on these cars, seems the NGK V-power plugs and the MSD wires and coil pack are the way to go. There is an active thread or two about this
what ever you get just go a step colder. also don't spend too much neon's run the same on cheopo's. and also a boosted car goes trough then alot faster than normal
i dont know why the granatelli's didnt work, but apparently i wasnt the only one that had that problem. im sure you read my other thread. i havent had a lick of problems since i installed my stuff. i picked up a set of ngk iridium plugs at work yesterday and probably going to throw them in this weekend, but now i have the v-power plugs in.
well they said i could get the msd wires when they came back in stock but when i got home there was an email saying that my order was shipped. so im guessing the shipped me the granatellis? if so i guess ill try to use them and hope they work... we'll see i guess. is there anyone who has had success w these?
