ATX trans will not downshift on it's own.
Old 08-31-2009, 08:11 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
DOHCgarrett t3 is offline
Default ATX trans will not downshift on it's own.
Like the title says The trans will not downshift on its own and when I am approaching a stop sign the Van will shutter and sometimes stall. I know this is a Second gereration Neon list but it has the same 2.4 l and trans that comes in the caravan also.
I just did a tune up, trans fluid and filter change. what else should I look for?
Old 08-31-2009, 09:28 PM
DOHCgarrett t3
anyone?
Old 09-01-2009, 09:48 AM
DOHCgarrett t3
nothing?
Old 09-01-2009, 10:48 PM
DOHCgarrett t3
well since no one answerd my question I went to a trans shop. When I got there the tech took it for a test drive and found that the trans was locking up too soon and also not unlocking. In order for the tech to determine if it was an electrical issue or mechicinal issue he unpluged a 2 prong wire that went into the trans and it still maintained it's shudder durring braking. which he then decided it was a mechinical issue either with the torque converter or "fluid going in the wrong place". The tech mentiond either way the trans has to come out.
Old 09-02-2009, 03:05 AM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
anyone?
nothing?
God forbid someone doesn't have the answer for you in an hour and a half...
How old is the fluid? Miles/time?
Old 09-02-2009, 11:27 AM
Captansavaho's Avatar
Captansavaho
Captansavaho is offline
idk if its the same for 1gens and 2gens but if its auto there is a bolt that sits right under 2nd gen neons intake(under the battery for 1st gens) and supposedly if its not shifting right you turn it till its tight then back it out like 2 1/4 turns or so...see if that helps any search the 1gen forms i know i have seen this problem before
Old 09-03-2009, 01:06 AM
darthroush's Avatar
darthroush
Section Moderator
There is a bolt that hold down the shifter cable lever holder thing on top of the transmission. Never heard of that trick of it it works on the 2gn's. Then again though, 03-05 are different transmissions as well, aren't they? The electronic ones?
Old 09-04-2009, 01:33 PM
DOHCgarrett t3
There were 17 people viewing the post when I bumped it up (granted, some people leave their browser running, so the totalks may be inaccurate.. Don't be an ***.
Miles : 112000, time: Unknown. Fluid: Didnt I state it was NEW?
Old 09-04-2009, 01:35 PM
DOHCgarrett t3
as far as I know from 79 - 2001 are the same transmissions A670's or TH31's\
Old 09-04-2009, 01:38 PM
DOHCgarrett t3
Yes, I think I know the bolt you are talking about. internaly it adjusts the tension and the bands. I may have that overtightend.
On another note: it was not the torque converter. I have replaced that and the problem still exists.
Quick Reply: ATX trans will not downshift on it's own.
