Have you guys changed your timing belt/water pump?
#31
I check the RockAuto parts catalog and they list two similar Gates part numberss:
TCKWP245A and TCKWP245B. From the link that darthroush posted: http://chronoscender.freeservers.com...imingbelt.html
and the corresponding Gates part pictures, the difference is the tensioner. Would the correct part to buy for a 2003 2.0L be the TCKWP245A?
Thanks
Thanks
#32
From: Dodge Neon Part Numbers, Maintenance Intervals and Fluid Capacities
"A" includes a new bracket, where "B" doesn't include one.
TIMING BELTS AND COMPONENTS
Timing Component Kit; W/Mech. Tensioner; Includes Bracket
- Gates Timing Belt Component Kit W/Water Pump- TCKWP245A
- Gates Timing Belt Component Kit- TCK245A
- Gates Timing Belt Component Kit W/Water Pump- TCKWP245B
- Gates Timing Belt Component Kit- TCK245B
#33
darthroush,
I realized I should also do the thermostat when I do my timing belt replacement.
Is this the correct part#: 05278144AA
Source: http://www.moparpartsoverstock.com/p...5278144AA.html
If I'm reading the description correctly it's the thermostat + seal/gasket
#37
I have ~900 miles before mine is at the 105,000 mile mark. Comes up pretty quick when you average ~2,000 miles per month, lol. I plan on changing them then. If one "had or has to" change their timing belt before or after that mileage, they probably had to change their head as well.
