Oil Consumption
Old Jul 20, 2010 | 06:09 PM
ottoretto's Avatar
ottoretto
Default Oil Consumption
hi fellows... i got a problem on my 2002 SOHC neon, the car while ago is consuming like an half of liter weekly of oil!.. the car is not smooking.... so what it can be the problem? i changed the valve sealer and is the same
Old Jul 23, 2010 | 03:07 AM
briann510's Avatar
briann510
Check the oil pressure sensor. Mine was leaking like crazy a qt every 300 miles. You can just reach your hand around back of the head and feel if its all oily on the sensor and know pretty quick if thats it.
Old Jul 23, 2010 | 04:20 AM
darthroush's Avatar
darthroush
Section Moderator
Yeah, those things do come loose at random...
Old Jul 23, 2010 | 05:47 AM
briann510's Avatar
briann510
Mine wasnt loose but just leaking through the sensor itself. Goofballs that replaced it for my daughter broke the one I mailed down to her to put in. Finally did it myself to make sure it was done right.
Old Jul 23, 2010 | 01:19 PM
darthroush's Avatar
darthroush
Section Moderator
My sensor was about 2 turns from falling out of the block, with pretty much no sealant left on the threads. Though, with probably about 2 or 3 actually in the block, it wouldn't have done much good. I put extra sealant on the new one.
Old Jul 24, 2010 | 06:13 PM
ottoretto's Avatar
ottoretto
i checked and nothing, the car is not leaking oil from anywhere! and is a lot of oil that is consuming! what else can be the problem??
Old Jul 25, 2010 | 03:25 AM
darthroush's Avatar
darthroush
Section Moderator
If the car is not leaking oil, it is blow-by somewhere in the engine, which will make it's way out the exhaust. Worn/bad rings are a common place for that to happen on higher mileage, or abused, engines. That's why you can just buy re-ring kits for engines. How many miles on the engine, and how many miles do you drive a week? Do you drive those miles spirited?
Old Jul 25, 2010 | 12:48 PM
bone33's Avatar
bone33
maybee your dipstick is shrinking.
Old Jul 25, 2010 | 09:00 PM
ottoretto's Avatar
ottoretto
haha! that is not funny X_X.... iunno! can be the pvc?
