neon hesitation
Old Mar 30, 2011 | 07:02 PM
jennives80's Avatar
jennives80
Default neon hesitation
I have a 2004 Dodge Neon and im having hesitation problems..it happens when its in park and at stop lights and when driving...ive changed the plugs and i have also changed the coil pack and it is still happeneng any suggestions?
Old Mar 30, 2011 | 07:43 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Neon section,
FF
Old Mar 30, 2011 | 07:56 PM
showsxt's Avatar
showsxt
Have you checked your motor mounts could be them or it could just be normal mine hesiates off and on within the 7yrs I have had her almost.
Old Mar 30, 2011 | 11:11 PM
Moparkyle's Avatar
Moparkyle
I would check motor and tranny mounts like SXT said, they can let the engine rock a lot which would make it seem hesitant.
Old Mar 31, 2011 | 12:57 AM
darthroush's Avatar
darthroush
Section Moderator
Worn mounts won't cause an engine to hesitate, providing the engine itself is actually hesitating. Sounds more like a tune-up is in order.
Old Mar 31, 2011 | 11:52 AM
showsxt's Avatar
showsxt
Yeah could get new plug wires and a new air filter and an oil chance and see if all that helps out It you had vibrating inside really bad than it would be the motor mounts but from what your saying its more like darth said a simple tune up which means new wires and oil change and air filter and check your other fluids . Also check your tire pressure in all 4 tires to see if they are the same and at the right pressure.
Old Mar 31, 2011 | 01:40 PM
jennives80's Avatar
jennives80
the thing is i just bought the car this month and the guy i bought it from said he changed everything...its just really frustrating....im almost positive that its not a motor mount....im starting to think the motor isnt getting enough fuel but im just a girl so what do i know right lol
Old Mar 31, 2011 | 06:03 PM
darthroush's Avatar
darthroush
Section Moderator
Do the spark plug wires look new? If you remove the spark plugs, do they look new? Are they copper plugs? Are they gapped correctly?
It could also be something that isn't normally changed until it goes bad...like the IAC valve.
Old Apr 1, 2011 | 08:27 AM
jennives80's Avatar
jennives80
yes they look new...im not to sure what the IAC valve is??? yesterday the engine light came back on....the dodge people said they could put it on the machine and it will tell me what it is but right now i dont have the $90 that it costs
Old Apr 1, 2011 | 10:41 AM
showsxt's Avatar
showsxt
Take it to autozone they do it for free to check your engine code .
