Losing oil
Temp fix is a catch can inline from PCV to intake, this will just stop oil from entering intake which in turn will burn and carbon up the internals ( valves ) which will cause lost performance. You will still lose oil into catch can but at least you will know where it is going.
More permanent fixxes include replacing valve cover with a gen 1 valve cover, pulling head and installing an oil restrictor near cylinder 4 and having the "return" oil ports in head opened up a tad.
The above can be done in stages, each stage will improve conditions greatly.
I can get you the part # for the oil restrictor ( it's a dodge OEM part )
I also believe some guys found a somewhat cheap plastic filter housing ( fuel filter ) that worked.
The issue is the oil restrictor is not small enough in head, so more oil can get to head, then the returns are to small so oil pools in the top, add a right hand turn say speeding up on an on ramp to mix and you can suck 1/8th a quart right down PCV into intake.
My car was eating about 1/4 quart a week which sounds about the same as yours and no oil leaks worth mentioning.
I live in the mountains. All of the roads are curvy but I don't think most of the oil is being lost into the intake (last time I looked anyways it wasn't much at all). I still should put a catch can on due to the poor valve cover design. Anyways, those oil pressure sensors can cause quite a bit a oil to come out. They can get loose too. n Mine was only threaded in a few threads. Either way, if there is oil pressure in the engine, it is being pushed out of that port/threads since they are no longer sealed.
