Losing oil
#21
Some cars eat alot of oil, some don't, no rhyme or reason to it. Some people have even reported there air filter box filled with oil from the vent tube.
The catch can is still a bandaid however it can help greatly as far as performance is concerned due to no longer burning oil in the combustion chamber ( also helps preserve rings as oil burns hotter increasing wear on rings )
The problem can go as far as to get so much oil up in top end ( note under full sustained redline conditions such as racing ) that the bottom end can run dry for a second or 2 increasing lower end bearing wear tenfold.
#22
Ok so next things on my list to do are catch can, clean out intake system, 1GN valve cover, then the head later on down the line. For the intake gaskets, can I just use the old ones with some RTV for the time being? I'm assuming they're rubber since most of the other ones I've dealt with are too.
#23
#25
Forced air induction and or high performance applications and or higher flow oil pumps ( melling 20PSI more than stock ) just compound this issue more and installing a catch can will not and can not eliminate the issue where you can run the bottom end dry due to all oil pumped up top.
Most people that run these cars hard do all of the above + add a larger moroso oil pan and add the catch can for performance reasons.
@ Bud unless using the magnum intake reusing the old intake gasket even without RTV would be something that you would have to determine once removed, if its to squashed i'd just get a new one, they are fairly cheap.
I'd avoid using a filter inline. The intake pulls a significant amount of vaccuum, i'd be concerned with it sucking a filter right down the tube.
#26
I thought about using the filters and decided on another idea, just waiting for it to dry to try it out. I had a medicine bottle, RTV, steel wool, pens, a 5 hour energy bottle, and some clean hose laying around so I did a little redneck engineering and came up with this:
![Name: IMG_20111015_185546.jpg
Size: 96.8 KB](https://dodgeforum.com/forum/attachments/2nd-gen-neon/61365d1501330439-losing-oil-img_20111015_185546.jpg)
![Name: IMG_20111015_191228.jpg
Size: 70.9 KB](https://dodgeforum.com/forum/attachments/2nd-gen-neon/61366d1501330439-losing-oil-img_20111015_191228.jpg)
The duct tape is only temporary til it dries and I paint it. Then I'll get some A/C repair tape as a sort of heat shield.
#27
Should work out ok, it's not under pressure but it will pull vaccum, If you have a vaccum gauge I would block one side and pull some vaccum on it just so to ensure it doesn't casue a vaccum leak.
This is what some users end up using for cheap money but requires bi-weekly checking.
http://www.gasgoo.com/auto-products/...0/1051447.html
For weekly or better users were using something comparable to this.
http://www.harborfreight.com/12-Air-...b-001b2166c2c0
#28
#29
This is the "popular" DIY catch-can. A lot of kits use this same filter. I have used it on another vehicle, and will probably buy a couple for my other cars.
http://www.amazon.com/Campbell-Hausf.../dp/B000BOAFGO
#30
