Low idle after vehicle warmed up
Thanks bro I really appreciate if you could email me the picture blackout33@live.ca
Thanks again let me know how she runs for you!
Goodnight
Goodnight
Let me know how it goes for you bro
Also can you send me the picture to blackout33@live.ca
I greatly appreciate it.
Thanks bro goodnight!
I did that to mine, an had nothing but high idle issues down the road. Esp when the a/c was on or the rad fan during 115 degree out side temp in stop an go traffic.
I did drill the hole in the butterfly years ago, which helped dramatically. Even after I replaced all vac lines, and vac. caps there was still a lower idle.
I turned the screw also, then turned it back after doing more research. Apparently it's not a good idea. Since I drilled a 1/8 hole in the throttle plate, I've been real happy with it. It idles about 700 rpm now when I'm sitting at a stop light, which might be a little high, but at least I don't have that annoying vibration any more.
Hey Guys couple weeks ago had my passenger side upper and lower mounts replaced since then im still having vibration thru the steering wheel when stopped at a light.
I have no idea or clue how to get rid of the vibration I called mechanic told me to come back I retorqued them same issue.
Its a after market mount so I dont know if that makes a difference
He checked my other mounts and they all seemed fine
Im puzzled and stumped at this point
Ive put brand new plugs gapped @ 35
Brand new wires
Cleaned throttle body
Ive done it all that I can think of.
I dont see any vacuum leaks he even checked for that as well
Any help would be greatly appreciated.
When I bought this vehicle it never had a vibration issue at all so smooth.
Its only got 147 thousand clicks
Is it better to have a OEM Dodge Mount installed would that make a big difference???
I also just recently had to replace the car starter on it new battery and also changed the belts vehicle runs quiet but when @ a stop light the steering just vibrates annoying the heck outta me!
LOL
I like smooth vehicles
Idle is between 600-700 which apparently is fine
I had a PCM update on it as well couple weeks ago for low idle issue and that didnt help it out at all
Any help would be greatly appreciated!
Brand new wires
LOL
