2000 Neon JERKING.
Old Nov 18, 2012 | 09:05 AM
  #41
Vegas Mike's Avatar
Vegas Mike
On my non-Neon car, if the vacuum line to the tranny is disconnected it shifts *hard*. Could that be a problem here?
+1 on the Fix the TCC wiring first. The wiring on my Neon was all screwed up in front of the drivers side of the engine, which included the TCC loom. Pulling the battery and tray or looking from underneath can check condition.
Old Nov 18, 2012 | 09:07 AM
  #42
cheapez's Avatar
cheapez
Originally Posted by darthroush
Two things. 1. Employers do check your credit. Those who are responsible tend to pay their bills. 2. What does that have to do with this thread (perhaps I missed something about Craigslist scammers in previous posts)? Let's keep it on-topic please.
Darth,
I'm swearing at the car. The bolts won't come out for me .
I checked the employer website, it was created a few days ago, no company logo, no phone, location, ... He tried to trick me, so I pay to see my credit score.
I keep it on the topic from now.
Old Nov 18, 2012 | 02:00 PM
  #43
Moparkyle's Avatar
Moparkyle
Probably the vacuum line to the transmission Vacuum modulator. I don't know enough about the 31TH to know if it has one of those or not.
Old Nov 18, 2012 | 03:25 PM
  #44
cheapez's Avatar
cheapez
+1 ^^^^^^^^
Brittany,
Some cars use throttle linkages, other cars use vacuum lines. They do the same thing (Shift late when you step on the gas petal). If your car has a vacuum line, you may have unplugged it when you worked on the TCC.
This vacuum line/vacuum hose is plugged into the intake manifold, and it goes to the transmission vacuum modulator.
Old Nov 18, 2012 | 04:58 PM
  #45
BrittanyLeigh's Avatar
BrittanyLeigh
The tcc wiring looked fine. Some of the electrical tape was mangled but none of the actual wires appeared to be damaged. I'm wondering if replacing my harness would be a good idea. Might be able to get in and have another look on thanksgiving. I'm interested in this vacuum stuff, could anyone provide me with a link that could provide me with more info?
Old Nov 19, 2012 | 11:47 AM
  #46
Vegas Mike's Avatar
Vegas Mike
On the TCC wiring, mine looked "acceptable" but ratty. It was taking a resistance reading across the TCC plug that found the missing insulation. I put an ohmmeter on the two leads in the TCC plug and I found an intermittent short. It read open but when I moved/wiggled the wiring harness, it went to a short. The wires that were missing insulation were inside the cloth that surrounds the wires - couldn't see it. PM me if you want to discuss the troubleshooting process.
Mike
Old Nov 19, 2012 | 12:10 PM
  #47
BrittanyLeigh
Thanks mike, will pm you when im at my computer and not on my phone.
Old Feb 22, 2018 | 01:13 PM
  #48
jay_2208's Avatar
jay_2208
New Member
ive been trying to find the tcc solenoid male connector an cant find it any place ive looked at auto zone advance google rockauto an every place in between why can i not find the connector for the tcc ive found a couple but not the one i need pls anything helps
Old Feb 22, 2018 | 01:35 PM
  #49
Might try a junk yard. And please, use punctuation and capitol letters. What you wrote is very difficult to read.
Old Feb 23, 2018 | 01:27 AM
  #50
darthroush's Avatar
darthroush
Section Moderator
There are links to parts manuals in the stickied threads section. It should list the connector number. Quite likely It’s going to be a Dodge only part.
