Rough Idle When Stopped
Old 07-14-2015, 02:34 PM
RPB_IA's Avatar
RPB_IA
RPB_IA is offline
Default Rough Idle When Stopped
Hi Everyone,
New to the forum and still very new to working on my own vehicles, so please bear with me .
So my wife has a 2005 Neon and it idles very rough when it is stopped at stoplights. It only does it when stopped and in Drive, if I put it in Neutral or Park it goes away, and also goes away when we start to accelerate.
We have already had the spark plugs replaced and that didn't help. Then the mechanic thought it might be because the rubber was gone on the motor mount (I think?) so he replaced that, and now it seems like it is even worse. I'm tired of getting yanked around and paying mechanics to fix stuff that isn't broken so now I'm here. I am VERY green when it comes to fixing vehicles, but starting today I'm going to slowly learn because I'm tired of shelling out big bucks to mechanics and dealers.
What do you all think it could be? Is it something that a newbie mechanic like me could try to fix?
Thanks in advance!
Old 07-14-2015, 02:58 PM
jkeaton is offline
Dodge Forum Administrator
How many miles? Which engine? Check engine light on?
Old 07-14-2015, 03:11 PM
RPB_IA's Avatar
RPB_IA
RPB_IA is offline
The car has about 145,000 miles, but it has been doing this for the last 2 years/30,000 miles or so. It is the 2.0L engine and the check engine light is not on. It is not just a slight shake either, it is like a rattle-your-teeth shake. She has just been putting up with it but I would like to fix it if possible because it is super annoying and I'm afraid that it could cause further damage in time.
Old 07-14-2015, 03:18 PM
richards83's Avatar
richards83
richards83 is offline
Do you know which "motor mount" he replaced?
Do you have a tachometer? If you do, what is your idle speed when you are stopped and in drive?
Old 07-14-2015, 04:03 PM
RPB_IA's Avatar
RPB_IA
RPB_IA is offline
Honestly, I have no idea. I just gullibly nodded my head as he explained to me what he thought was wrong with it. I don't think there is a tach on the dash but I can look in a few days, the car is currently sitting at the airport parking lot since my wife is out of town. Sorry I can't give more information :/
Old 07-14-2015, 07:59 PM
jkeaton is offline
Pretty bad if you don't know if you have a tach. Lol. Really can't do much for you if you don't have the car in front of you to do some basic troubleshooting. Post back when you have the car back.
Old 07-14-2015, 11:19 PM
RPB_IA's Avatar
RPB_IA
RPB_IA is offline
^Haha yeah, I don't drive the car much so can't remember about the tach off hand. Like I said, I'm very new to this too. Will post back when she gets home.
Old 07-16-2015, 02:17 AM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Dodge Forum Moderator
Unless it was an SXT, it wouldn't have a tachometer from the factory. The motor mount (assuming it was the actual motor mount) was likely replaced with an aftermarket mount which isn't a filled mount like the Dodge one. That could be a contributing factor and/or the strut mounts weren't aligned. The whole mount situation seems to be the main cause of the bad vibrations in these cars.
Old 09-06-2015, 04:31 PM
boatmoter's Avatar
boatmoter
boatmoter is offline
have to check out the condition of all 4 mounts, if they are OK, then you will need to do a engine mount adjustment procedure
Quick Reply: Rough Idle When Stopped
