OBX headers
Old Apr 29, 2006 | 09:56 AM
spudsterier's Avatar
spudsterier
Default RE: OBX headers
stainless steel isnt supposed to rust....thats the point of stainless steel
Old May 11, 2006 | 04:23 PM
NHARINTON's Avatar
NHARINTON
[&o]
Just installed the tusido headers and down pipe (exactly the same as obx) and am throwing cel code p0420 which is a cat code??????
is thier a way to stop this???? hopefully without having to have a cat welded in?? thanks in advance
Old May 12, 2006 | 12:16 AM
spikeymikey87's Avatar
spikeymikey87
well o crap i have them in the mail and now i need a solution to that too.
Old May 12, 2006 | 02:58 PM
NHARINTON's Avatar
NHARINTON
ok the fix is at modernpreformance or jegs!! they make a o2 sensor that is fake and tricks the computer!!!
have not lookeed into prices yet though. and you will really like the headers and downpipe. the only thing i recomened is to heat wrap them, or get them coated as they get extremly hot!! good luck with the install
Old May 12, 2006 | 06:49 PM
moobit's Avatar
moobit
So if i install headers will i need that 02 sensor, or is it throwing that code because you installed the downpipe??
Old May 12, 2006 | 07:19 PM
NHARINTON's Avatar
NHARINTON
it is giving the code because i installed the down pipe which removes the cat. if you leave the stock downpipe you will have to xtend it to meet the stock exhaust pipe, which is not that hard. or you could get a down pipe with a high flow cat, which is not that exspensive.
or keep the obx down pipe and get the new ("fake") sensor
hope this helps!
Old May 12, 2006 | 08:43 PM
spikeymikey87
i couldnt find that o2 sensor could you send me a link please
Old May 13, 2006 | 09:07 PM
NHARINTON's Avatar
NHARINTON
here is a cheap universal one (but i dont know if it is very good):
http://www.o2sensorsimulator.com/?OV...OVMTC=standard
Here is the one jegs sells from the maker (casper electronics) :
https://www.casperselectronics.com/M...Category_Code=
and if you are any good at making circuts and crap here is directions on how to make one:
http://mkiv.com/techarticles/oxygen_sensor_simulator/
i am just going to get the one from casper, dont want to take the risk it does something bad to my computer.
Old May 14, 2006 | 03:05 AM
spikeymikey87
ok let me know how they work on your car
Old May 8, 2007 | 01:52 AM
pcman's Avatar
pcman
I was wondering, which headers you two were going with, the OBX Race header or OBX header and down pipe? And also what solution proved to work with eliminating the check engine light after the cat was removed?
