OBX headers
Old Apr 10, 2006 | 03:46 AM
spikeymikey87's Avatar
spikeymikey87
Default OBX headers
hey i was looking on modernperformance.com and i was looking at the OBX headers and i wanted to know what you guys thought of them. do they fit perfectly with stock? is says that they come with a downpipe does that replace your cat? and does it have to be used. also what kind of gains should i be expecting
Old Apr 10, 2006 | 03:22 PM
03neonRT's Avatar
03neonRT
Default RE: OBX headers
OBX headers are direct replacement...no welding or special piping required.
Old Apr 11, 2006 | 12:54 AM
spikeymikey87
does it the downpipe it comes with replace the catalytic converter and what kind of gains would i expect from it?
Old Apr 11, 2006 | 01:18 AM
03neonRT's Avatar
03neonRT
No only a Long Tube header will replace your catalytic converter. You should expect anywhere from 6-7HP(maybe 3-4WHP) from new headers.
Old Apr 11, 2006 | 06:18 PM
spikeymikey87
this is the picture they give you from modernperformance.com is this the headers exactly? and it comes with a downpipe and the header and downpipe both have holes in them(o2 sensor maybe) and my catalytic converter has an o2 sensor in it and its on the downpipe of the car which it looks like is being replaced. i dont mean to be annoying, im just confused. where does the catalytic converter go?
[IMG]local://upfiles/27482/437BD5CC33E641F3A6DEC6AC55B48246.jpg[/IMG]
Old Apr 11, 2006 | 11:07 PM
leadspud's Avatar
leadspud
Yes the down pipe replaces the cat. I do not know what kind of gains you will get. I'm running the OBX header and down pipe on my car. I think it took a little more than a hour to put in.
Old Apr 12, 2006 | 01:35 AM
03neonRT's Avatar
03neonRT
Well if your getting a short header that will replace the cat with a longer downpipe, you might as well go with a longtube header...you'll seee more gains that way...
Old Apr 14, 2006 | 01:15 AM
Freerider's Avatar
Freerider
just to warn you, i dont know if the OBX headers are treated or not. I dont believe they are, so if you purchase them youd have to send them off to be heat treated or coated so they dont rust up on ya.
Old Apr 15, 2006 | 04:56 PM
leadspud's Avatar
leadspud
The OBX headers are stainless steel
Old Apr 29, 2006 | 05:14 AM
2003SXTneon's Avatar
2003SXTneon
The obx headers are stainless steel, does that mean they need to be treated????
