Old Apr 4, 2013 | 08:01 PM
  #10671
gdstock's Avatar
gdstock
Originally Posted by bourassa.p.pb
Today my 2009 Dodge Ram (5.7L Hemi) ran out of engine oil, the light came on and the engine died. I filled engine oil and now it runs terrible and the doesnt maintain oil pressure. Now on an older truck i would condemn the crank bearings because of the lack of oil pressure but i assumed that a newer truck would have some kind of protection against this kind of thing from permanently damaging the engine incorporated into the programming in the ECM.
Does anyone know if there is a limp mode in this make/model/yr of dodge and how to get it out of limp mode if there is? Or is my engine in need of rebuild?
Ran out of oil? The only protection against that is the owner/driver periodically checking/adding oil as needed. Technology cannot do everything!
Sorry, but engine is toast!
Old Apr 4, 2013 | 08:25 PM
  #10672
PCM doesn't care about oil pressure. It will let the engine run forever with zero pressure. As you discovered... Ooops.
Old Apr 4, 2013 | 09:00 PM
  #10673
QuadCabLuv's Avatar
QuadCabLuv
WOOOOOOWWWWWWWWWWWW.
On another note, i came home to find my new cylinder head sitting on the front porch. I will be taking the old one off on sunday!!!
Old Apr 4, 2013 | 09:05 PM
  #10674
stewie01's Avatar
stewie01
Did you ever find what caused the misfire (or was that the other truck?) Or is the new head project part of it?
Old Apr 4, 2013 | 11:13 PM
  #10675
boyceh79's Avatar
boyceh79
Ram was making a popping sound. When i turned . Was worried it might be the R&P. Tie rods looked a lil worn. So I figured Id try them before I dumped a couple notes on a rack. Good news is tie rod end fixed the problem. Bad news is I could only get one changed. Pounded and pounded like hell, but couldn't get one side to break free of the control arm. WTF.. Any advice????? Short of an air hammer?
Old Apr 4, 2013 | 11:18 PM
  #10676
stewie01's Avatar
stewie01
BFH! Bigger Farking Hammer
Most people around here seem to NOT advise this, but you might heat it up a tad and a good whack and it'll probably pop right out.
When I had to replace the idler arm on my truck I bought a "pickle fork" to pop it out, nope, didn't work, bought a cheap **** blow torch and bam, 1 hit with the pickle fork and it came right out
Old Apr 4, 2013 | 11:35 PM
  #10677
gdstock's Avatar
gdstock
R&P? What is that....because it surely isn't rack and pinion...
Old Apr 5, 2013 | 10:37 AM
  #10678
Hey now, MY build sheet says POWER RACK AND PINION Steering..... although, I must admit, I have NEVER been able to find it......
Old Apr 5, 2013 | 12:50 PM
  #10679
boyceh79's Avatar
boyceh79
Did I say something wrong? I did mean rack & pinion. Im fairly new to working on my own stuff and to forums. I'm not exactly sure the lingo. But trying to make me look stupid doesn't help anyone.
Old Apr 5, 2013 | 01:02 PM
  #10680
Even though the build sheet SAYS Rack And Pinion, it is actually recirculating ball..... Chrysler used some technical tom-foolery to call it rack and pinion. And they still stick by that. Even though NO ONE ELSE in the industry agrees with them. It's actually kinda funny.
Don't take gdstock's post as personal. If you don't get a ration of feces here on a regular basis, you might start thinking we don't love you any more.
