I am a newbie to this stuff.
NPT is for the barbed ends? What is the threaded ends measured with?
NPT is National Pipe Tap. It is pipe threads, which are tapered. Pipe is measured on inside diameter, and tubing is measured outside. NPT is the sixe necessary to thread in pipe that measures 3/8" inside.
Even though the build sheet SAYS Rack And Pinion, it is actually recirculating ball..... Chrysler used some technical tom-foolery to call it rack and pinion. And they still stick by that. Even though NO ONE ELSE in the industry agrees with them. It's actually kinda funny.
Don't take gdstock's post as personal. If you don't get a ration of feces here on a regular basis, you might start thinking we don't love you any more.
looked at it so far. gonna pull the wide band, and make sure the o2 sensor isnt toast. for whatever reason, itll read fine for a minute, then go full lean for no reason. i know the thing is running pig rich, but the wide band isnt showing it. fun fun.
You need the sct. I wouldn't worry about it too much until u get it.
i already have the tuner. just need to order the custom tuning.
i need the wideband because i have the red injectors which ar 25lbs at 49psi. so i need to watch it. dont want to burn out my new cat. thats a good way to do that.
if the sensor is bad, i have to buy a new one cause it isnt covered under aem's warranty.
