Sorry but these shocks are combo fluid and gas with a coil spring on them. After they get used up they no longer help hold the suspension. I know, cause when I replace the shocks I always have to jack the trailer up higher when I want to hitch it.
Do not try to set the timing. The only timing adjustment is on the chain. It should still be set to spec unless you turned the timing sprockets durin installation. Turning the distributor on these engines does not work, it only changes fuel sync.
So i found out! No adjustments were really necasarry, seems to run just fine as is. Only other issue is I lost one of the bolts to hold the distributor down....
Did you even read my post? So you have whats called a load leveling shock (a shock with a spring on it or a cheap flavor of a coil-over shock) Make your posts clear about these things.
Yes I did. It is a load leveling shock. I don't think it is a cheap thing either. They are Monroe Sensa trac or something like it. Has something like a 1/2 inch thick coil spring on it. Also has fluid reservoirs to help it last longer when it starts to leak.
