Cut the runners and shortened the divider in my plenum before I swap engines. I'll pick up some carbide bits tonight, so I can smooth out the edges. I'll also use them to gasket match and bowl blend my heads while Im installing new valve seals and lapping my valves.
Also, I noticed in other peoples threads about the plenum mods, they eliminate the center divider. Mine has an EGR port, and a tube cast into the divider, so I just shaved off the material on top of that. Anyone else seen this?
Hmmmm..... Now the gears are turning. That sounds simple enough, if it works. Also, on my EFI swap thread, HeyYou mentioned EGR delete... Decisions, decisions...
on
Beter than 20.
