Old Sep 25, 2009 | 10:52 AM
  #1451
Relex's Avatar
Relex
Changed my front diff fluid today.
0924091454-00.jpg?t=1253890311
I really need to get around to putting in a new axle seal.
Old Sep 25, 2009 | 12:35 PM
  #1452
Sheriff420's Avatar
Sheriff420
i just did both axle seals like a month ago. which one do you need to change? hopefully its not the driver seal, that ones a pain.
Old Sep 25, 2009 | 02:42 PM
  #1453
SpcD1500's Avatar
SpcD1500
Originally Posted by dodge15004x45.9
At least get pics.
oh there will be pics atleast.
Old Sep 25, 2009 | 03:10 PM
  #1454
Relex's Avatar
Relex
The drivers side is the one that is bad. Do you need an axle seal installer tool or is there another way that isn't so expensive?
Old Sep 25, 2009 | 03:21 PM
  #1455
95MaroonMonster's Avatar
95MaroonMonster
Originally Posted by PurplDodge
For $50 I'll wash, clay bar, and wax your truck. But you'll never get the truck back....
I finnaly fixed my driver's side speaker. Now it isnt as annoying to be in the truckwith the radio on.
fine, then i come and steal Purpl
Old Sep 25, 2009 | 04:31 PM
  #1456
Sheriff420's Avatar
Sheriff420
it should only cost about 25$. you need the 14$ seal, a tube of rtv and some new differential fluid.
you can use a 1 3/4" socket and a hammer to drive the new seal in. there isn't a stop for that seal so you will have to measure the distance from the old one to the outside of the axle tube first so you won't drive it too far in.
go by these and you won't have any trouble.
http://www.pavementsucks.com/tech/hub.php
http://www.pavementsucks.com/tech/axleseal.php
don't forget to use penetrating fluid on the hub nuts (1 11/16") and bolts (14mm 12 point).
pull the caliper mounting brackets off (21mm bolts) with the calipers attached and hang them from the shock towers with rope.
check out the u joints while you have the axles out.
pull the intermediate shaft out of the carrier or it will never come out.
and lube all contact points on the hubs with anti-seize before reassembly.
oh, and make sure you have a 3/4" drive breaker bar with a cheater pipe before taking the hub nuts off. and have a torque wrench that will go over 180 ft-lbs.
Old Sep 25, 2009 | 05:01 PM
  #1457
wald0's Avatar
wald0
i changed my o2 sensors, both n oil change.
Old Sep 25, 2009 | 06:49 PM
  #1458
dodgeboy1979's Avatar
dodgeboy1979
gutted my catalytic converter today
Old Sep 25, 2009 | 07:37 PM
  #1459
99_ramsport's Avatar
99_ramsport
Just got done installing my new sony xplod mex-bt3700u. Its a great HU! I love the bluetooth!!
Old Sep 25, 2009 | 10:38 PM
  #1460
pizzo's Avatar
pizzo
transmission troubles all day had to change the converter back to stock the better then stock one trashed. it was shifting funny checked and cleaned grounds first but no luck. i changed trans fluid a few weeks ago to transyn that my have had something to do with it but I don't know more in my transmission problems post
thanks Pizzo
