So far it’s survived several years in the FL sun/heat, and has been removed & reinstalled a few times, no issues.
Things no working are: radio, dome light, map lights, cargo light, glovebox light, under hood light, power mirrors, ignition halo.
So IOD fuse it is... took a few minutes to work out how to get the fuse out of the carrier (nothing in the owner’s manual), but I got it, and all is working again.
Just for you, here’s a pic of what I did.
I just cut a section from the top of the factory piece and taped it to the GlowShift pod with 3 strips of double sided tape.
The bottom tucks between the steel A pillar and the dash... the section with double sides tape applied is clipped into its location, and the pod is aligned and pressed firmly into place.
As you can see I had to epoxy the clip to the plastic some years before.
The double sided tape has held up well.
