Old 11-10-2020, 06:55 AM
pershingd's Avatar
pershingd
pershingd is offline
8.0s only had 8.4:1 compression ratios so it's hardly a high compression engine.
Still trying to find the time & decent weather to change out the upper control arms and install new bushing in the lowers on my beast.
  #16602
Old 11-10-2020, 03:29 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
I thought it was close to 10 boy was I wrong lol
  #16603
Old 11-17-2020, 03:04 PM
MoparFanatic21
Default Found 4 of these bad boys
So I bought them and installed the black one in my black interior
  #16604
Old 11-29-2020, 10:36 AM
1997DodgeRam's Avatar
1997DodgeRam
1997DodgeRam is offline
Default Finally broken in
Hit 200k. I realize for many owners on here 200k was a while ago, but as an original owner that doesn’t like to share, I was there for almost every one of those 200k.
  #16605
Old 12-08-2020, 11:33 PM
Brettcunningham1989's Avatar
Brettcunningham1989
Brettcunningham1989 is offline
98 ram sport 4x4 with a 5.2.
replaced:
front u joints
upper and lower ball joints
front wheel hubs
calipers, pads, and rotors
drums, shoes, wheel cylinders, and all the springs
all four shocks
plugs, wires, cap and rotor, ignition coil
thermostat
upper and lower control arm bushings(polyurethane)
power steering pump, hoses, and steering gear box
got 4 tires and an alignment
body mounts(polyurethane)
battery
steering damper
........I think that's it for now but list isnt done.
Alot if the play from the steering is gone but it still has some there. All the tie rod ends and track bars are good. What else could I adjust or replace to make it tighten up?
  #16606
Old 12-09-2020, 12:14 AM
MoparFanatic21
replaced:
front u joints
front wheel hubs
all four shocks
thermostat
battery
steering damper
Steering shaft. It has mini u joints they can go bad
The following users liked this post:
Brettcunningham1989 (12-09-2020)
  #16607
Old 12-09-2020, 12:30 AM
Brettcunningham1989
I will check this out asap. Does the whole shat get replaced or just the small u joints??
  #16608
Old 12-09-2020, 12:55 AM
MoparFanatic21
Whole shaft.
  #16609
Old 12-10-2020, 01:53 PM
Ramman18's Avatar
Ramman18
Ramman18 is offline
replaced:
front u joints
front wheel hubs
all four shocks
thermostat
battery
steering damper
Holy crap, that's nearly everything! I would double check your alignment to ensure zero toe in. Also, you don't mention a new track bar. That's a requisite. But I have a question: how did you bleed the steering pump? I can't get all the air out and the last thing I can try is a vacuum pump thing. So frustrating.
  #16610
Old 12-10-2020, 03:22 PM
Brettcunningham1989
haha yea it was alot. The alignment was the very last thing that was done so it's all good. I checked out everything underneath and there is no play left in it that I could find. For bleeding the pump, it took time. Filled the reservoir with fluid and turned the wheel 90 degrees from center both directions, slowly, until almost all the fluid was gone from the reservoir. Repeat this until fluid stops disappearing from the reservoir. At this point slowly go from lock to lock and pay attention to the fluid level. After doing all this you should be good to go. I didnt have to use the vacuum pump. I could be wrong but I thought that was only to make sure there were no leaks. Right or wrong I dont know but I haven't had any problems.
Quick Reply: What Did You Do To Your 2ND GEN RAM Today?
