Old Dec 30, 2020 | 12:53 PM
  #16621
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by frankie_b_jr
Guess I should have researched more because I didn't know there was a newer style. I just picked up what was available at a Napa close by.
I'm unsure on if the 99 and up have a bigger rotor but if they don't you could have used the 99 needing and rotor which will just slip off instead of being pressed on.
Old Dec 30, 2020 | 01:51 PM
  #16622
frankie_b_jr's Avatar
frankie_b_jr
Thanks for the info. I didn't know any of the 2nd gens went to outboard rotors. Just looked at Napa's website and the newer style is 12.850" diameter versus the older one at 12.500" diameter. Now lets see if I can remember that the next time I do the front brakes.
Old Dec 30, 2020 | 08:11 PM
  #16623
MoparFanatic21
Yeah when they went to dual piston calibers (99) they went to slip on rotors
Old Dec 31, 2020 | 01:55 PM
  #16624
Spillage's Avatar
Spillage
I got back to the visors that I stripped down when I pulled the headliner to recover that.
Below is a series of pictures of how I installed the headliner fabric on the visors.
After filing any bruising and sharp edges from the plastic.
I cut a section of headliner material a couple of inches bigger than that needed to wrap the visor.
I located the corners of the mirror pocket and cut an opening... tucked the flaps behind the mirror and snapped it into place.
I used a dull paint scraper to pry a gap between the halves, then used a coffee stir stick to push the fabric in between the teeth... I worked sections of an inch or so at a time.
When at the ends I trimmed the excess to leave about an inch to tuck in... by the time the material rolls around the edge, there’s maybe only a half inch that actually goes inside.
Once at the halfway point (one face done), I trimmed around the mount and folded the fabric onto the other side, and trimmed to the inch over mark.
I pulled a little tension on the fabric and repeated the pry and tuck process... if there’s too much excess it gets difficult to get it tucked in, so trim a little more off if needed, but don’t leave yourself short.
When done, I rolled the fabric edge under around the mount and tucked in the last bit.
At the other end I felt for the pin location and sliced an opening... the edges are then tucked in... I took a little too much out which made it difficult to get it tucked in enough (I may redo it because of this... we’ll see how the other one turns out).
Old Dec 31, 2020 | 02:24 PM
  #16625
Spillage's Avatar
Spillage
Here’s some more pictures just for good measure
Old Dec 31, 2020 | 02:32 PM
  #16626
MoparFanatic21
A+ job seriously!! You have more patience then me when it comes to upholstery
Old Dec 31, 2020 | 02:45 PM
  #16627
Spillage's Avatar
Spillage
Here’s a recap of the disassembly...
Old Dec 31, 2020 | 02:54 PM
  #16628
Spillage's Avatar
Spillage
It was surprisingly easy once I worked out the process... the tip is; go slow, take your time... and don’t trim too much too early.
The areas that pose the greatest difficulty are around the mounts... but again, if you have the material to work with, it’s not that bad.
Old Dec 31, 2020 | 04:03 PM
  #16629
MoparFanatic21
Does the mounting base of the mirror (where the 3 screws go) come off? I want to put 3rd gen visors in so they extend. I start out slow but then always rush because if I leave upholstery sit overnight and get up the next day it always gets dirty
Old Dec 31, 2020 | 06:15 PM
  #16630
Spillage's Avatar
Spillage
I’ll take a look and report back tomorrow.
Yup, I probably wouldn’t take on an upholstery job right after doing a timing chain.
