Old Jul 18, 2011 | 07:12 PM
  #5701
seaham358's Avatar
seaham358
Picked up a Duralast from AZ.. $115.. What happened to the $60 batteries??
I'm glad it was an easy fix. Installed the battery and took a ride around the block.
Old Jul 23, 2011 | 06:49 PM
  #5702
dsertdog56's Avatar
dsertdog56
I'm attending a show that benefits the Cancer Sucks foundation tomorrow. So it's been clean and polish and paint the truck today.
Old Jul 23, 2011 | 07:56 PM
  #5703
crazzywolfie's Avatar
crazzywolfie
you could probably get a good battery at a junk yard for cheaper. my local junk yard only charges about $20 per battery and they are usually real good batteries. the battery i bought for my 81 from the junk yard works way better than the one i had in it.
Old Jul 24, 2011 | 12:04 PM
  #5704
knoxy's Avatar
knoxy
Fixed drivers window. One of the bottom clips came off and the window dropped inside the door. Took it out, put some gorilla glue in the clip, stuck it back on the window, & let it set up over night. Put it back in the door, hit the switch & it rolled up again!
Old Jul 24, 2011 | 08:50 PM
  #5705
Ram4x45.9's Avatar
Ram4x45.9
1997 ram 2500 5.9 gas 46 re tranny.
Put superior shift kit in an sonnax intermediate servo an 3-4 accumulator piston.
Dont waste your money didnt help.
The only thing needs change is 3-4 accumulator cause its plastic and manual valve and throttle valve.I did the modification to the throttle valve in the superior shift kit
but didnt help.The only prob i have is shifts back to second from 3rd (too sensitive)
when it shouldn't.
Old Jul 24, 2011 | 08:54 PM
  #5706
Ram4x45.9's Avatar
Ram4x45.9
Tell us about the tranny probs youv'e had an what you did about them.
Lets make this forum usefull!
Old Jul 25, 2011 | 12:23 PM
  #5707
Ralpho's Avatar
Ralpho
I guess its time to sell my 1500 4x4 4dr sport Ram due to the ac quit and trans is leaking and starting to act up. Can't afford to fix it.
Old Jul 25, 2011 | 12:26 PM
  #5708
wilfite's Avatar
wilfite
Default Finally have my summer back!
Stayed up till 2 last night finishing replacing the heater core and cracked dash. Of course, after I pulled the dash all apart I found there were a couple of other approaches I could have taken that would have taken a couple hours less time (Doh!).
I now have a working, non-smelly heater and dash that doesn't rattle like a pair of Maraccas! This was the last in a big series of projects. I'll be incredibly glad now to reclaim my summer, thanks very much.
Projects done in the last two months:
-New front shocks
-New Tie-rods, replaced everything except Pitman arm and steering box. Steering box is a bit loose and I couldn't get the adjustment screw to break loose to adjust it, but I can live with it. It's not too bad.
-Alignment (rough)
-Plenum Fix with plate, this was a big project and I broke one of the intake bolts off. Was doing fine drilling it out until the screw extractor BROKE in the hole. It seems nigh impossible to drill through one of these, so I took a risk and put it all back together without that bolt. No leaks so far.
-New plugs
-Heater core replacement
-Cracked dash replacement, had an extra dash that came with the truck. Probably a junk yard dash.
-Replace Auxiliary backup lights. Old ones installed upside down and filled with dirty water. Not good for electrical connects and reflective surfaces...
-Replace bulbs in off-road driving lights. Not as easy as it sounds.
-Probably a hand-full of other things I'm forgetting.
One thing left to do, replace the AC condensor but no hurry. The one on the truck doesn't leak (though it's a miracle it doesn't!) but has a huge crease from a deer impact last year. I've had a new one sitting next to my desk for a while.
Phew!
Still need to pass emissions to get tags renewed, but should pass ok now that there's a good Plenum seal.
Old Jul 27, 2011 | 09:30 AM
  #5709
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Rode 1100 mi round trip from home to Kansas City and back in two days in my dad's truck.
(2002 Ram 1500 4.7)
Got 18 MPG on the way up there, 12.5 on the way back towing a U-haul that weighs prolly around 4500 lbs right now.
BTW, you people from OK, you're roads suck ***. At least the highway we were on.
One thing I did love though: NO ETHANOL!!!! WOOT!!
Some of those foothills in OK were a nightmare.
Soo, I get to be on the road again today, gotta take the load to its final location, drop it off, get rid of the U-haul, go back to homebase, pick up my dad's trailer, then head off to Dallas to pick up another something.
His truck will need work after this.
Old Jul 27, 2011 | 01:43 PM
  #5710
redheadhunter21's Avatar
redheadhunter21
Put the updated spectre plenum in, got my WOT back and get to use 4500 and up now, this might get me into some trouble
