Old Jan 9, 2012 | 11:08 AM
  #6231
Originally Posted by mjm1988
Recently discovered that I *do not* have the original engine in my '88 D100.....in my quest to discover the exact engine, I've managed to find the casting numbers for the block (appears to b 12 digits) as well as the time (casting clock and Day/Night indicator) as well as the casting date (8/24/84). Now, the question - there is supposed to be a 7 (?) digit engine ID stamped on the engine (somewhere near the cylinder head) - can anyone give me some clues as to where this last ID is located?? Right now I believe it is on the driver's side (firewall side, of course) near the cylinder head - worst place in the world as far as access......I'm sure some of y'all have been down this road before. The real kicker (and reason) for this egg hunt is that the oil dipstick that came w/ the truck is the wrong one, so I need to rectify this situation if I'm ever going to be able to determine the true level of oil in the beast!!! Thanks in advance for your time!!!! Magruber
So far as I know, they are on a pad right behind the drivers side head, on the part of the block that is 'bellhousing' shaped...... Which is going to be damn near impossible to read, with the engine in the truck. Creative use of bright lites, and mirrors??
Old Jan 9, 2012 | 09:24 PM
  #6232
BackwoodsRam's Avatar
BackwoodsRam
started puting the body filler on my console. im gonna try to have it ready to bedline by this weekend
Old Jan 9, 2012 | 09:41 PM
  #6233
Boris1059's Avatar
Boris1059
Took the old truck in for the annual safety inspection (registration is due).
Old Jan 9, 2012 | 10:51 PM
  #6234
1997DodgeRam's Avatar
1997DodgeRam
Ordered up the hughes plenum repair kit and intake bolts plus a distributor cap wires and a few other odds and ends. Depending on how fast UPS takes care of me I may be digging into a plenum repair this coming weekend. I figure after 15 years it is finally time to fix the original plate/gasket. I still think it is holding pretty well with none of the classic symptums but I got the check engine for the O2 and don't see the point in changing that or the CAT until I get the plenum done.
I have been reading up but may be looking for some crunch time crisis advice this weekend since it is my DD.
Old Jan 10, 2012 | 07:27 PM
  #6235
Boris1059's Avatar
Boris1059
Failed safety inspection yesterday...."excessive movement in the brake pedal". Time to take peek at the back brakes.
Old Jan 10, 2012 | 07:33 PM
  #6236
stewie01's Avatar
stewie01
Might as well replace the PCV valve while your doing all this, get one from the dealer, $7.50 from my local shop.
Old Jan 10, 2012 | 07:36 PM
  #6237
stewie01's Avatar
stewie01
Drove it to work today, put gas in it, missed my exit on the way home because I was on the phone
Cleaned all the river muck off the truck yesterday, it was starting to stick too.
Old Jan 11, 2012 | 09:48 PM
  #6238
BackwoodsRam
i coated the inside of my console with rubberized coating and did a bunch of sanding on it
Old Jan 11, 2012 | 10:09 PM
  #6239
Nereaga's Avatar
Nereaga
Replaced rear shocks last week, mind you they were the dodge stock ones after 150K, not pretty.
Today tried to replace the fronts, bottom nut/bolt no problem... Top one was not so easy, in fact, snapped a small ratchet trying AND snapped a nipple off an adapter for a bigger ratchet... just not my day. Taking it to my bosses shop to get some reinforcements, as my backyard mechanic tools are not so good... lol
Old Jan 12, 2012 | 02:34 AM
  #6240
Wh1t3NuKle's Avatar
Wh1t3NuKle
Cleaned up all the damn tools spread around the durn truck!
