Old Mar 20, 2012 | 05:49 PM
  #6731
silverram2000's Avatar
silverram2000
Just received my crossover steering, and ordered the new bds rear leads and drop German arm
Old Mar 20, 2012 | 05:51 PM
  #6732
silverram2000
Pitman arm
Old Mar 20, 2012 | 08:57 PM
  #6733
johnnyjaws98's Avatar
johnnyjaws98
replaced the drag link. Over the past 3 weeks i have completely rebuilt the whole front end, except the steering box and thats next saved a ton of money doing it my self spent around $ 900.00 on parts thank god im good at mechanics
  #6734
dsertdog56's Avatar
dsertdog56
Built a "hub adapter" for my spare holddown so I can mount my factory chrome rims. Yes, the round part was cut from an old hub bearing.
Old Mar 21, 2012 | 07:38 PM
  #6735
redneck_ram's Avatar
redneck_ram
installed my hughes underdrive crank puleey tonight.
pulley was an easy install, but the belt...thats a whole nother issue.
i had to bypass my facory a/c compressor last saummer because the bearing went, so i used a 90" belt to bypass it, so i had no clue what size belt i needed.
well it took 2 seperate trips to advance to get the right belt.
the correct belt size is 87.5" 875k6 is the part number. for a truck without the a/c bypassed it will be a 95" belt and the part number is 950k7 so you will need a belt 2.5" shorter.
so far i have noticed a slight improvement on throttle response, and takeoff is better, and my voltage is under 14v at idle, but comes back after you step on the gas.
Old Mar 22, 2012 | 08:09 PM
  #6736
Wh1t3NuKle's Avatar
Wh1t3NuKle
Default Sliders
Frame plates cut and mostly prepped.
Sliders beveled.
Piece of scrap test fit for cap.
I need paint suggestions, which I think would have to be a dark color. The kids are going to decorate them with any color/design that 5 yr olds can imagine.
Old Mar 22, 2012 | 08:23 PM
  #6737
Rhino line 'em. Tough, durable, maintenance free.
Old Mar 23, 2012 | 04:05 PM
  #6738
stewie01's Avatar
stewie01
Took her down to the river today, drove across the spot we did the last time we were there, it's MUCH deeper this time, it came up to my hood.
We started to suck in water through the intake, I thought we were gonna stall out, but the ole' girl did good
Old Mar 24, 2012 | 01:15 AM
  #6739
97black_ram's Avatar
97black_ram
The hub buster. Found it amusing. Does it work like the video, don't know.
http://youtu.be/G4pygRExlus
Old Mar 24, 2012 | 10:18 AM
  #6740
xlstreetglide's Avatar
xlstreetglide
Truck wouldn't turn over, tracked it down to ignition coil, replaced it started right up. Maybe I'm imagining it but it runs like a different truck. Is that possible?
