have you checked all the fuses including the ones under the hood. i know you said you wired the stereo to the battery but did you run both positive wires to the battery or just the constant power wire?
I ran the constant through the original wiring, and the main power straight to the positive terminal. I have checked the fuses.
to me it sounds like you must have damaged the constant power line somewhere since your stereo and headlights quit working. you should maybe take a volt meter to the fuse boxes and see what fuses are not getting power that should be like your headlights.
Forgot to mention, jiggled the headlight switch connector around last night and now I have head lights. My gauge cluster lights up when I turn the headlights on, and the high beam indicator works as well. That's it though.
bought some autolite 3923 plugs today. advance only had 7 in stock, and i took those, and will pick up the 8th plug tomorrow. hopefully this will solve my misfire issue, that i cant seems to shake.
dont worry, im not going to install the new plugs until i get them all in my hands.
