The Official 2nd Gen RAM Forum OT thread
Old Jul 2, 2013 | 09:38 PM
  #10191
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
That's a lot of damn cows.
Old Jul 2, 2013 | 10:24 PM
  #10192
aofarrell2's Avatar
aofarrell2
Still not sure why you didn't just carb the Magnum. lol Better head design anyhow.
Only problem is the mechanical fuel pump, amiright?
running carter AFB 4bbl vacuum secondary on Magnum 318 with mag heads. Using LA vacuum advance dizzy as it bolts right into the block. Funny thing is that the PCM engages the fuel pump... i'm using a holley regulator to step down the factory 50psi pump to the 3-5psi that the carb needs.
Problem is PCM refuses to run the gauges. I'm tempted to try datalinking with the PCM and see if it will talk to me and tell me why it won't do what it is supposed to do.
But at any rate, the ultimate goal is to be rid of the darn PCM for good. And that is about to happen very shortly.
http://www.dakotadigital.com/index.c...prod/prd48.htm
That will take care of my cruise control Probably use HND-7 for the handle, so it operates as my steering tilt and my cruise control.
Old Jul 2, 2013 | 10:31 PM
  #10193
crazzywolfie's Avatar
crazzywolfie
i am pretty sure the pcm don't control the gauges. the sensors on the engine should do that.
Old Jul 2, 2013 | 10:33 PM
  #10194
dodge dude94
Well, I'm glad you didn't down grade to an LA.
Old Jul 2, 2013 | 10:34 PM
  #10195
aofarrell2's Avatar
aofarrell2
PCM controls tachometer, speedometer, voltmeter, IDK if this ram is one that uses the PCM to run the fuel level gauge as I know some did. It never adjusts the fuel level unless the PCM is plugged in.
Old Jul 2, 2013 | 10:35 PM
  #10196
dodge dude94
All gauges are controlled by the PCM.
Old Jul 2, 2013 | 10:36 PM
  #10197
aofarrell2's Avatar
aofarrell2
Somehow if I unplug the PCM my temp gauge and oil pressure gauge work
Old Jul 2, 2013 | 10:37 PM
  #10198
dodge dude94
Old Jul 2, 2013 | 10:44 PM
  #10199
crazzywolfie
i told you the computer don't control that crap. the speedo should also work when you get the truck mobile.
Old Jul 2, 2013 | 10:46 PM
  #10200
aofarrell2's Avatar
aofarrell2
Computer DOES control the tach, I've verified this with my Chrysler certified tech who DOESN'T lie, it also says it in black and white in the FSM.
And yes the speedo is controlled by the PCM, I have a VSS in my transfer case. I had my speedo working back when the engine was EFI, it worked without the rear dshaft hooked up since it was in the tcase. Tried it now and it didn't work.
Remember crazzy, this is a 1996 OBDII compliant (from factory that is) truck.
