The Official 2nd Gen RAM Forum OT thread
Old 07-03-2013, 11:41 AM
aofarrell2's Avatar
aofarrell2
aofarrell2 is offline
Now on page 8E-4, here's what it says about the tach:
Now it says on the same page that the speedometer receives its signal right from the VSS, so the speedometer is independent of the PCM. What it doesn't say is which wires do what on the speedo.
  #10232
Old 07-03-2013, 11:50 AM
stewie01's Avatar
stewie01
stewie01 is offline
My bunny rabbit has been bad the last few days, she's chewed though 3 mice cables and chewed up the speaker cable...
Bad bunny...
  #10233
Old 07-03-2013, 12:02 PM
aofarrell2's Avatar
aofarrell2
^Uh oh... Boy stewie, I didn't know you had so many pets...
  #10234
HeyYou is offline
Dodge Forum Administrator
Received 3,266 Likes on 3,013 Posts
White wire with orange trace is VSS input signal. So far as I can tell, that should be the only wire you need to make the speedo work.
Three wires at VSS:
Light blue: Sensor ground
Orange: 5 volt supply.
Both of those are to/from the PCM
White with orange trace: Signal wire. This has a splice that also goes to the PCM. Probably for cruise, and a couple other purposes. (trans for instance....)
Attached Thumbnails The Official 2nd Gen RAM Forum OT thread-1996dodgefsm_zps4ed08dcb.png
  #10235
Old 07-03-2013, 12:05 PM
aofarrell2's Avatar
aofarrell2
So which pin on the back of the speedo is signal, and which is ground?
  #10236
Old 07-03-2013, 12:15 PM
HeyYou is offline
Shouldn't have to do anything on the back of the speedo, so long as all the wires are still in the connector for the cluster. Just make sure you are getting 5 volts to the sensor.
  #10237
Old 07-03-2013, 12:17 PM
aofarrell2's Avatar
aofarrell2
Well that's the problem, I will be running a custom cluster, so while I may be able to use the factory speedo, I might not be able to reuse the PCB on the back.
  #10238
Old 07-03-2013, 12:23 PM
HeyYou is offline
Trial and error then. The speedo will work either way, I should think. Just the odo may run backwards.
  #10239
Old 07-03-2013, 03:43 PM
QuadCabLuv's Avatar
QuadCabLuv
QuadCabLuv is offline
This came into the shoo today. Holy bondo barman!
Pics don't do it justice. that dent is about 2.5" deep. And they were going to just fill it.
  #10240
Old 07-03-2013, 03:48 PM
stewie01's Avatar
stewie01
stewie01 is offline
abLuv/IMAG0130_zpse23b78db.jpg[/IMG]
Your pic no work.
Quick Reply: The Official 2nd Gen RAM Forum OT thread
