The Official 2nd Gen RAM Forum OT thread
No, but I am a self proclaimed gynecologist....
on
on
1 Post
Only $6 at Northern? I would have assumed $20, they charge way too much for everything.
on
That's kinda what I think. Don't wanna pull it out though, not sure what it's attached to...
Disclaimer: I am not a veterinarian nor am intending to take the place of a veterinarian. I take no liability whatsoever for any damages incurred by following my advice.
In my experience here's what works.
You'll need cayenne pepper and olive oil. Mix enough of each together to make a paste that will thoroughly cover the wound. It should not be a stiff paste but not terribly runny either. After cleaning it, apply the solution. It may burn or sting bad, but it will both disinfect the wound and kill any parasite or bacteria. It will also draw more blood flow to the wound to allow faster healing. Just a note: More than likely the dog will want to lick it even more, it is IMPORTANT to prevent this as much as possible, if you need to use a neck cone to prevent it from turning its head enough to be able to lick it's leg. It is best to apply it once a day at the beginning of the day.
And optionally, in addition to the above, you can put some raw honey on the wound at the end of the day after cleaning it again. This will sting at first but will eventually help to sooth it and encourage faster healing.
Hope this helps, it is what I have done.
Lemme know what you do.
