The Official 2nd Gen RAM Forum OT thread
Old Jan 29, 2014 | 06:02 PM
  #15091
stewie01's Avatar
stewie01
I think I'd need new shorts:
Old Jan 29, 2014 | 06:40 PM
  #15092
Spillage's Avatar
Spillage
Seemed to be traveling a little fast for the conditions, and no hint of slowing down on first site of the semi... it took a while for it to register, and react.
Old Jan 29, 2014 | 07:21 PM
  #15093
Spillage's Avatar
Spillage
Originally Posted by Ham Bone
Anyone ever installed an oil temp guage?
Half way there...
Have the gauge mounted and wired... just need the filter sandwich block the mount the sensor.
Will eventually have an oil cooler, but that's not needed yet.
I added the oil temp to fill a spot in my gauge pod, and give me a way to double check the (notoriously) less than accurate stock water temp gauge.
As a side note;
When I added LT Headers, one of the engine mount heat shields got damaged... I considered removing them when I take the mounts off to install the engine mount inserts to lessen the torque deflection of the engine.
The headers are further from the engine mounts than the stock exhaust manifold, so I figured less radiant heat on the mount.
Well, now that I have this oil temp sensor wired and hanging in the area, I bagged it (to keep the threads clean) and tie wrapped it to the top of the heat shield.
It so happens that on an 80°F ambient day, after an hours highway run, at most the area sees 122°F when you pull up and sit idling... hardly an earth shattering temp that is likely to damage the engine mount, so removing the heat shields wont be detrimental... there is likely more radiant heat from the side of the block.
Old Jan 29, 2014 | 10:16 PM
  #15094
aofarrell2's Avatar
aofarrell2
http://youtu.be/Ce9lF_9m7yQ
Yeah I would too.
Lots of people in the comments are like the guy with the dashcam was going to fast, but I don't think he was. Dashcams always make things seem faster than they really were, and the other semi driver going up hill was just plain being DUMB, passing on snowy roads, past a plow. Down here at least it's illegal to pass a plow on conditions like that AFAIK.
Old Jan 29, 2014 | 11:16 PM
  #15095
Ham Bone's Avatar
Ham Bone
Originally Posted by aofarrell2
Yeah I would too.
Its illegal to kill people and snort crack but that has never stopped them
Old Jan 30, 2014 | 12:03 AM
  #15096
merc225hp's Avatar
merc225hp
Going to be looking at this old M135 6x6 on the weekend, he has two to look at this one and a bobbed one with no motor or xcase, but he has a IH motor tarnny and xcase that would fit in it. I have no spec's on the IH stuff until I see it this weekend.
http://classifieds.castanet.net/deta..._truck/689535/
Old Jan 30, 2014 | 12:38 AM
  #15097
tincan57's Avatar
tincan57
Funny you should mention this Merc. I was just on Craigslist (couldn't sleep).
US Craigslist posting
I have for sale a "bobbed" 1971 M135A2 deuce and a half, for work, play, parades,
four wheeling, hunting, zombie killing,anything and everything! Its big! has a
6 cylinderturbo diesel (multi-fuel) engine, 5 speed Spicer transmission, Hi-Lo
transfer case, and 4x4.it has just at 25,000 miles and 1000hrs. on the clock,
with less than 200 on newer engine. One axle was removed along with the original
bed and the frame shortened 3ft, then added an M105 trailer bed and leaf springs
to make it a pick up truck. I swapped the original tires for a set of newer 14,5R20's
(43" tall) on military bead lock wheels, I have two spare tires and wheels that come
with it. This build has been done the right way, similar conversions on this truck
cost $2500+. Its very dependable, starts first time every time even in - temps and
has plenty of power.
for info call or text ford, dodge, Chevrolet, chevy, cummins,
powerstroke, duramax, cat, caterpillar, Detroit, peterbilt, kenworth, semi, international,
mack, 4x4, 6x6, Rockwell, dana, john deere, case, tractor Location:
do NOT contact me with unsolicited services or offers
post id: 4299875996 posted: 7 days ago
EDIT 1. I took the poor guys phone number our to protect the innocent, but have it if you want it. K
K.
Last edited by tincan57; Jan 30, 2014 at 12:57 AM. Reason: Dropped a 1 on 135a Some reason/got rid of state/PHONE
Old Jan 30, 2014 | 10:17 AM
  #15098
Yeah, how about slowing down a little. Probably one of those idiots that texts and drives. I'd be embarrassed to show that to anyone.
Old Jan 30, 2014 | 12:54 PM
  #15099
Jigabop's Avatar
Jigabop
that nissan engine would make a great go-kart engine!
Old Jan 30, 2014 | 01:07 PM
  #15100
Johnn123's Avatar
Johnn123
That would be what you call super mario cart
