Educate Me Please
Old Dec 4, 2010 | 03:40 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1000..............
Old Dec 4, 2010 | 03:59 PM
Originally Posted by dodgeram07
does your motor?, smoke, ping, knock, low oil psi
if no, i wouldnt do no thing,,, your engine has 200,000miles so it has were patterns and replacing interns with out machining your going to have problems
i would bank the money ,,,,,, and buy zman's parts
just my 2cents
***just read what HeyYou said , sorry to repete*********8
Originally Posted by zman17
+1000..............
Wow, I think you should get zman's parts too......
(hey zman just send the check to........ i'll pm the address. )
Old Dec 4, 2010 | 04:19 PM
Gerehead8's Avatar
Gerehead8
At 200K as someone mentioned your motor was at you don't just put rings and pistons in. The motor will need to be rebuilt and that includes machine work $$$$. You are looking at at least $1000 for just a basic bottom end rebuild (machining and parts for the block). Getting the heads done or getting new ones are costs on top of that.
The 360 is a 4" bore and the 318 is a 3.91" bore.
MP comp should be able to be used on a stock motor but will require premium fuel.
Old Dec 4, 2010 | 06:59 PM
95RAM360's Avatar
95RAM360
hmmmmmmmm....i know someone who can do the machining....he did my flywheel for my maxima, my intake for my ram, and hes done my u-joints....very good on price...ill have a chat with him, he works in a professional machine shop.
and no theres nothing wrong with my motor, it runs excellent.....like i said pre mature maintenance.....somewhere dwn the road it will need to be done, although when i took off my VC's last my valve terrain is pretty clean.
Old Dec 5, 2010 | 01:51 AM
lastrights's Avatar
lastrights
you could always get the 1.7 HS for now see how that does ? def would be noticable feel with the 4.10 you have
Old Dec 5, 2010 | 07:32 AM
95RAM360's Avatar
95RAM360
yea that would be a great start, just to see how those help alone....and since its a bolt right up part, i may look into it....
Old Dec 5, 2010 | 11:04 AM
lastrights's Avatar
lastrights
have you modded your TB yet ? you could take a dremal to the air horns so that air gets sucked into the throttle body better ,it helps with thottle responce easy and free
Old Dec 5, 2010 | 12:01 PM
95RAM360's Avatar
95RAM360
nope havent done it, and dont have access to a dremal...
Old Dec 5, 2010 | 08:06 PM
lastrights's Avatar
lastrights
you can get one at wal mart for 20 bucks
here the fastman you can make yours look the same but with out boring it out Name:  wm_normal_255837.jpg
