craigslist score!
Old Dec 11, 2010 | 07:21 PM
Cool Deal!!! Now, time to load it up with stuff.
Old Dec 11, 2010 | 07:22 PM
bardram's Avatar
bardram
Default craigslist score!
Ive been looking for a decent toolbox for my bed. Finally came accross this one and talked the guy down to $75! Perfect for what I need.
Old Dec 11, 2010 | 07:49 PM
bardram's Avatar
bardram
I'm kicking around the idea of hard wiring a DC to AC power converter to the inside of the tool box, so I can have an outlet to run power tools right in the bed. Drop the tailgate and have a little mobile work bench.
Old Dec 12, 2010 | 12:01 AM
dodgeram07's Avatar
dodgeram07
cool,,,,, i got power converter and lights in mine the 2 best things i ever did
Old Dec 12, 2010 | 12:31 AM
crazzywolfie's Avatar
crazzywolfie
i went to the junk yard today and saw an inverter mounted to the under side of a hood
Old Dec 12, 2010 | 11:37 AM
redheadhunter21's Avatar
redheadhunter21
All this talk of power inverter and know I'm really itching to install mine, I'm doing it in the cab somewhere though need it to charge my labtop and a couple other things plus I'll get a little extension cord, and be able to go all around the truck.
And the toolbox looks good reminds me I have to do something with mine
Old Dec 12, 2010 | 01:01 PM
Cartalk2's Avatar
Cartalk2
What size inverters are you going ofor???
Old Dec 12, 2010 | 01:09 PM
crazzywolfie
if you are planning to run power tool you would probably need at least a 1000w inverter. i know where i live you can get a 1000w inverter for about $100. the only thing is you have to hard wire it straight to your battery but you might want to put it on a relay so that it will only be on when you truck is on and running or you may end up with a dead battery.
Old Dec 12, 2010 | 02:01 PM
bardram's Avatar
bardram
I saw a 1500w cobra on amazon for $95. That might be the one. It has to be hard wired to the battery, which is no problem, these trucks are easy to wire up. I will probably run a switch in the cab so I can keep it off until I need it.
Old Dec 12, 2010 | 02:56 PM
crazzywolfie
that is a good deal considering it is 1500 Watts Continuous Power, 3000 Watts Peak Power. it would probably be a better idea to install it in the cab so it don't get damaged by moisture or cold weather. like i said before it would be a good idea to put it on a relay and wire it so that it can't go on without your key being in the run position and have your truck running. i had a 400w one and with my laptop and internet modem hooked up it would drain my truck battery to the point where i could not start my truck in less than an hour.
