Help - My Truck Won't Run
Old Sep 7, 2011 | 11:05 PM
  #111
stangs13's Avatar
stangs13
Originally Posted by seabass202
well that settles it. I am gonna pack up in Grandmasbox, Minnesota and move to friendswood, Texas. we were only rated 69!
Welcome aboard!
Old Sep 7, 2011 | 11:07 PM
  #112
gdstock's Avatar
gdstock
Default gauge
Originally Posted by stangs13
How could we be so naive, hows the hookers and blow gauge reading?
So if the gauge reads "low" what would that mean? Is this two separate gauges?
Old Sep 7, 2011 | 11:21 PM
  #113
aim4squirrels's Avatar
aim4squirrels
shawty got low.
Old Sep 8, 2011 | 01:26 PM
  #114
stangs13's Avatar
stangs13
Nope only one gauge, , hookers and blow is hookers and blow it should never run low.
Old Sep 8, 2011 | 01:54 PM
  #115
Gary-L's Avatar
Gary-L
Veteran: Navy
You are my hero.
Old Sep 10, 2011 | 07:17 AM
  #116
NYJohn's Avatar
NYJohn
You will never get to the root of the problem with formating like that.
One sentence paragraph's.
Then end it with any thought's or your thought's or idea's.
Lastly need to sign your name.
If you do not use this procedure we can not get to the root of the problem.
I am the Senior Industrial Applicant of Mechanical Unilateral Phase Detractor's.
So trust me i have seen this many time's on a "no start" condition.
5v wire ground's out the modial interaction of the magneto reluctance and capacitive directance of the differential girdle spring.
What's happening is the differential girdle spring close's the dingle arm thus causeing the "no start" condition.
If you do not get this fixed you will get major ambaphascient lunar wain shaft side fumbling which is never good trust me.
Have i mentioned I am the Senior Industrial Applicant of Mechanical Unilateral Phase Detractor's.
Have a look and report back with "any thought's or idea's".
CARL
Old Sep 10, 2011 | 07:55 AM
  #117
Prototype's Avatar
Prototype
I signed up just so I could subscribe to this thread.
Please keep us updated because I no of a few trucks that have a similar no start problem.
I know it was already mentioned, but did VW check the headlight fluid?
I was once told by a guy wearing what looked like a red suit of armor that that might be a problem.
Thank you for the advice on how to format my posts NYJohn.
I would have looked like an idiot without your help.
Prototype
-CEO of 'The Headlight Fluid Store'
! Thanks for the laughs guys!! !
Old Sep 10, 2011 | 09:37 AM
  #118
charlie1935's Avatar
charlie1935
CARL
I've seen this in the past.
The differential girdle spring fails to reset properly and causes a no start condition.
Charlie, grouchy old fart
Old Sep 10, 2011 | 10:44 PM
  #119
Prototype's Avatar
Prototype
C'mon guys, we can't let this die. He needs help getting his truck running.
Old Sep 10, 2011 | 11:25 PM
  #120
gdstock's Avatar
gdstock
CARL
I should have thought about that! I had the SAME problem with a 62 VW Beetle one time!
