Help - My Truck Won't Run
Old Aug 31, 2011 | 01:31 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
How do I fix this?
Old Aug 31, 2011 | 01:33 PM
aim4squirrels's Avatar
aim4squirrels
Usually 3 things cause a no start condition: no air, fuel, or spark.
Check for obstructions to the air filter and verify the TB blades operate freely. Then check for fuel st the rail, and verify spark by pulling a plug and grounding it to the frame.
If one of those doesn't check out, we can delve into more detail later.
Old Aug 31, 2011 | 01:37 PM
zman17's Avatar
zman17
Retired Moderator - RIP
As stated many times here on DF. Check the muffler bearings and make sure the blinker fluid isn't burnt. While your at it, make sure there isn't too much gas in the water.
stewie01's Avatar
stewie01
Best way to solve the problem is to trade in your 2nd Generation for a 3rd or 4th Gen. Or go buy a Ford.
Old Aug 31, 2011 | 01:40 PM
zman17's Avatar
zman17
Wrong, to check the spark (in VW's case) he needs to put his tongue on the coil wire. If his head explodes, the coil is good.
Old Aug 31, 2011 | 01:41 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
How do I know if it's getting spark? Where's the fuel rail? I know I put gas in it so it has fuel, right?
Old Aug 31, 2011 | 02:15 PM
zman17's Avatar
zman17
Make sure you check the "speed of my internet" with a gauge, you might have a loose lug nut, or your tool box is leaking.
Old Aug 31, 2011 | 03:32 PM
zman17's Avatar
zman17
Don't forget, remove the diodes(not just open them) to check the flux capacitor.
Old Aug 31, 2011 | 03:36 PM
drewactual's Avatar
drewactual
wow.. so many things to do.. so many things it could be.. let's start a list for him:
1. exchange the stale air in your tires. buy only Sandia National Laboratory certified air for replacement.. our trucks don't like aftermarket for some reason, and often refuse to roll on it..
2. make sure and swap the air in the spare too.. you can get by with mother mopar air for it though, and save a few dimes..
3. (please take this and roll with it until he figures it out)
Old Aug 31, 2011 | 03:44 PM
It won't run? Will it walk? How about jog? Maybe you have the wrong tires on it??
