Your Plenum Gasket Pictures -- Post Up
Old Dec 31, 2011 | 01:02 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Cool Your Plenum Gasket Pictures -- Post Up
I've seen some of yours here and there all over this forum. However, the photo-memory is not what it used to be in going back to find them all. So maybe this thread could be a collection of them. The collection would serve to flaunt our pride/joy of the effort having taken to access them as well as a good reference for others to see what might be the condition.
So provide (if you don't mind) picture(s) and the MILEAGE. Include any other helpful characterization.
Miles: 126K
Gasket Blown? (yes/no): NO
Replacement? (yes/no/other): Yes -- M1
Classic baked on oil bottom of plate, which is above the valley
Scraped the goop off
Plate off, showing the PCV oil bake on (normal!), Gasket intact
The all info thread about the Plenum Intake Gasket, all should read: https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Dec 31, 2011 | 02:00 PM
merc225hp's Avatar
merc225hp
Replaced on 09/2010 at 124.274 mi. Current mileage 159.071 12/2011
Gasket Blown? : NO The gasket was broken when plenum plate was removed
Replacement? : Yes M1
Replaced with this Mopar M1 Mpi Intake non egr.
Old Dec 31, 2011 | 02:13 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I was going to say something in another thread a few days ago about what the OEM gasket looks like. Now I don't have to.
Old Dec 31, 2011 | 02:53 PM
UnregisteredUser's Avatar
UnregisteredUser
Talk about a public service! Kudos, WN. It's important for people to be able to see what normal PCV system deposits look like -- especially so with the persistent myth that anything other than shiny steel on the top of the belly pan is an indication of failure.
Old Dec 31, 2011 | 03:06 PM
Yeah, mine sure didn't look like that though.... Wonder if it was MINE that had been into before, and they put in the cork gasket......
Old Dec 31, 2011 | 03:25 PM
zman17's Avatar
zman17
Not like Ive done a 100 but ive never seen a cork one before. I do know, that at some point, Dodge made an upgraded gasket. The oldest one Ive worked on is a 97, and thats what the gasket looked like. Loose bolts and all.
Old Jan 1, 2012 | 12:44 PM
stewie01's Avatar
stewie01
Here's my plenum pictures:
Gasket Blown: Appeared so
Replacement: Hughes Plate and gasket
Miles: just under 148k
Wh1t3NuKle's Avatar
Wh1t3NuKle
I'm amazed you remained content still.
Thanks sir. I felt it was necessary to highlight this aspect of anything related to evaluating the plenum gasket condition. I've seen many a posts where (imo) the quick assumption of a blown gasket was stated in the absence of better evidence. I will say that one that does not get 100% confirmation until they have pulled the plate physically. The only other way would seem to pull the entire throttle body off and a super visual inspection, among other things.
So you old-timers, I mean vintage dudes, I mean bad asses could put up your pictures OR as best you can note your mileage, condition, and replacement method.
Old Jan 1, 2012 | 12:53 PM
I had about 165K on mine, and it was most certainly blown out. Four places at least. Some parts of the gasket were missing completely.... (no clue where they went, and I didn't find them in the oil pan when I did the pump either....) I didn't get pics...
Old Jan 1, 2012 | 12:59 PM
zman17's Avatar
zman17
You do know the topic is plenum gasket right? Not VC or trans pan!
