Motor swap project started
Old Jan 28, 2013 | 03:09 PM
  #121
QuadCabLuv's Avatar
QuadCabLuv
He better not be. I made it clear to him that, thats not how you adjust the timing. He txtd me and said the check engine light came on so hes at oriellys getting the codes read.
Old Jan 28, 2013 | 03:44 PM
  #122
QuadCabLuv's Avatar
QuadCabLuv
Burped the coolant several times and temp wants to hover at 229 deg. We put a new thermostat in it and it ssems to be working. Is it possible that the channels in the intake manifold are plugged up? If so anyone have any great ideas to verify or fix?
Old Jan 28, 2013 | 03:46 PM
  #123
Probably still has an air bubble somewhere.
If the intake manifold coolant passages get plugged, you have a MUCH bigger problem... they are pretty fair sized, and even with zero maintenance should never really plug up.
Remind me what year is the rental truck?
Old Jan 28, 2013 | 08:43 PM
  #124
QuadCabLuv's Avatar
QuadCabLuv
It is a 95.
so after closer examination the new mopar thermostat was not working. due to time and money we just removed the thermostat and put it back together. at least he will be able to drive it now, i hope nothing else goes wrong for at least a couple of weeks. lol
I didnt have enough time to try and figure out why its ideling high still. It hovers around 1300 rpm and drops to about 850 when in gear. I am going to plug off all the vacuum lines except for the pcv and the brake booster and see what happens.
Old Jan 29, 2013 | 12:42 PM
  #125
QuadCabLuv's Avatar
QuadCabLuv
Im thinking that it just needs a new radiator. I am going to put the thermostat I took out in a pot of water and heat it to 200 deg and make sure it is opening when it should. If it is then i will replace the rad.
