E Fan and other work
Old Apr 24, 2012 | 02:00 PM
gdstock's Avatar
gdstock
Default E Fan and other work
Now that the paint and body work is nearly done, I am preparing to order an electric fan and replace carpet in my Ram.
Anyone know of a lower price option than http://www.tcpperformance.com/2068736.html. Current cost is $585. I found this on hereTheyCallMe Laramie's DIY. I want a quality fan set up, but this price seems a little high.
I found several sources on the carpet and have ordered samples to match color and pile and well as thinckness of backing. I will be installing sound deadening as well.
Old Apr 24, 2012 | 03:01 PM
Wombat Ranger's Avatar
Wombat Ranger
I am awaiting my single 19" Grand Cherokee fan that I am going to mount in the factory shroud... With a wiring kit it cost me about $100 total for 4000+cfm...
Otherwise there is this kit, and you could add a shroud.
http://www.ffdynamics.com/ramB.html
http://www.ebay.com/itm/DODGE-RAM-AD...ht_1776wt_1163
Old Apr 24, 2012 | 03:18 PM
gdstock's Avatar
gdstock
Originally Posted by 2x1972
I am awaiting my single 19" Grand Cherokee fan that I am going to mount in the factory shroud... With a wiring kit it cost me about $100 total for 400+cfm...
I saw those, but the shroud is the part I cannot find. I know the OEM shroud won't work, but seems to be little in the way of affordable options. I know to have one fabbed here locally would be prohibitive.
Old Apr 24, 2012 | 03:26 PM
drewactual's Avatar
drewactual
man, i've got about $150 in my rig, and it has worked flawlessly...
i retained the factory shroud without any modification whatsoever..
most of the coin was spent on controllers and relays, with good heavy gauge wiring up next, then fuse packs.. I used 10ga from the battery to the controller, and 12ga from the controller to each fan..
for the fans themselves, i bought two 2750cfm eBay fellers.. i look at them almost as a consumable part.. they are 16".. one is pushing while the other pulls.. they overlap slightly over the center of the radiator..
i've never seen the truck break 195* with them on there, and that was in a pretty demanding situation..
edited to add: I could easily have got out of another $50, and had just as effective a system for $100, but I liked the idea of heavier than needed wiring, and pretty little shrouds for all of it..
my rig is a pseudo third gen ('02), but the same concept can work for you easily too..
spend the money in the wiring- and replace the $20 fans as needed.. there is no need to spend wildly on these pre fabbed kits, in my opinion..
Old Apr 24, 2012 | 03:37 PM
Wombat Ranger
Thought about the Grand Cherokee fan?
Jasonw had the FFD kit with the TCP shroud, I don't know if that would be any cheaper...
Old Apr 24, 2012 | 08:40 PM
Ugly1's Avatar
Ugly1
You can get the TCP shroud by itself without their fan kit and it's like $200 IIRC. That allowed me to save quite a bit on my install as compared to their full on kit price. Had I thought of the 19" fan I probably would have done that instead cause I'm a cheapass and even though I really love how the TCP shroud has cleared out my engine bay and looks all trick....Point is: make sure you use a shroud with the conversion otherwise your fans will stay on much longer largely negating the benefits of the efans.
Old Apr 24, 2012 | 09:59 PM
gdstock's Avatar
gdstock
I can't find just the shroud on their website. Guess I will have to call them tomorrow. I may just drop the cash to get the kit.....may be some value in warranty and make installation easier.
I do like the concept of clearing out the engine bay for a less crowded look under the hood and allow more access there.
EDIT: I ordered new AC Condenser and drier. Replaced compressor a while back but have it blanked off and have not used it due to damaged condenser (surprised it doesn't leak), so it is time to get this replaced as well. It was nearly 90 here today, so summer is pretty close!
Old Apr 24, 2012 | 10:41 PM
Wombat Ranger
Yes, with temperatures climbing, I am getting more and more impatient to get my fan installed... Not so much for A/C though, I'm more of a windows down kind of guy until the temps get stupid hot.
Old Apr 24, 2012 | 11:31 PM
QuadCabLuv's Avatar
QuadCabLuv
Dido and my a/c quit working last week.....
Old Apr 25, 2012 | 10:58 PM
gdstock's Avatar
gdstock
Has anyone used the Primus IQ Electric Brake controller? I am looking at installing a controller. I have used Tekonsha in my Yota and several other vehicles over the years, but never a Primus. I do want the proportional rather than timed.
