Wheeling a fullsize
  #91
Old 05-09-2013, 06:22 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
The spring perches will be removed completely and new ones put on. That is the pretty much the fab work. Other than that, regear and axleshafts. Probably new brake pads too. Rotors should be fine.
  #92
Old 05-13-2013, 10:09 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Ok, here is the portion that did the following beauty mark.
It's shown in realtime so you get a sense of the pace. It's quite painful and is also why I slapped in a few songs.
  #93
Old 06-01-2013, 05:31 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Default Broke Vacuum line at CAD - fix + extension
On the run in the previous post, at some point I over drooped and overextended the vacuum line on the CAD. The red one to be specific. This is good news as you are still able to engage/disengage 4wd. The only issue becomes vacuum havoc on your HVAC. My A/C would do the classic stop when the engine was under load.
I ordered the harness part from autopartsasap.com, but they are NOT ASAP. Ordered on May 23 and received May 31.
Mopar 52105299AB Vacuum Front Axle Harness for $31
Here is what you get:
I then decided to EXTEND the line to not break it again.
Picked up some unions and such from VatoZone
My hard lines were fine, so keeping that for spare.
Now installed
Maybe this will help someone out.
  #94
Old 06-01-2013, 05:43 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Default SJ 5" Coils and Custom Rear Leaf Hangers
Got some SJ 5" Coils for free, so I put them in along with 14" Bilstein 5125 shocks.
The shocks only come in two mounting sizes, 1/2" with a sleeve or 5/8" w/o a sleeve. Dodge bolt is 14mm ~0.56" plus the brackets are not flush to the shock. So I had some sleeves made that were 3/4" OD seamless DOM, with ID for the stock Dodge bolts, and finally cut to length to match the brackets.
I then used my rotozip to open up the ID of the rubber bushings from 5/8" to 3/4". Done. For the front I got some JKS Shock Mount Conversions so no more stem. So only 6 new sleeves and bushing mods were done out of the 8 total.
Here is the initial install.
I knew my uptravel (~1.5") was going to be an issue, but not "how much". hahah It's not fun bottoming out....I was very careful.
So...
Now about 4" of shock showing. These SJ springs are soft!
Messed up the Driver side Leaf Hanger:
So...
  #95
Old 06-02-2013, 01:00 AM
Wombat Ranger's Avatar
Wombat Ranger
Wombat Ranger is offline
Those shackles are sexy.
  #96
Old 06-02-2013, 09:12 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,228 Likes on 2,978 Posts
Holy smokes. I don't think you are going to bend that shackle any time soon. Nice work.
  #97
Old 06-02-2013, 12:01 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
h3lzsn1p3r is offline
the shackles are beef.
  #98
Old 06-02-2013, 01:08 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
Those shackles are skookum.
  #99
Old 06-02-2013, 05:10 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
^thanks dudes.
and what does skookum mean? lol U Canadians.
Gotta to cap the holes and paint. What color?
  #100
Old 06-02-2013, 05:23 PM
merc225hp's Avatar
merc225hp
Originally Posted by Wh1t3NuKle
^thanks dudes.
Skookum is a Chinook Jargon word that has come into general use in the Pacific Northwest.
http://en.wikipedia.org/wiki/Skookum
It has a range of positive meanings. The word can mean 'good,' 'strong,'[2] 'best,' 'powerful,' 'ultimate,' or 'brave.' Something can be skookum meaning 'really good' or 'right on! 'excellent!', or it can be skookum meaning 'tough' or 'durable.' A skookum burger is either a big[3] or a really tasty hamburger, or both. Homecooked food described as skookum, is delicious and hearty. A person described as skookum, has a purpose and is on solid ground, and in good health and spirits. When used in reference to another person, e.g. "he's skookum," it conveys connotations of trustworthiness, reliability and honesty as well as (possibly but not necessarily) strength and size.
Quick Reply: Wheeling a fullsize
