Wheeling a fullsize
Old Jul 21, 2014 | 09:46 AM
  #551
redneck_ram's Avatar
redneck_ram
Fwiw If you go to change those bj's while you have it apart don't use Moog, step it up a few notches $$$ wise. I just replaced mine after a year of very light use.
Merc! Long time no see! How have you been?
From what ive seen and heard, moog has gone down in craftsmanship in the last 5 or so years. I refuse to use moog, but I havent had to replace any bjs on my truck yet...
Old Jul 21, 2014 | 10:14 AM
  #552
Wh1t3NuKle's Avatar
Wh1t3NuKle
^He said NOT to use Moog.
No pics yesterday b/c the light went away.
Progress was:
Upper link cut to length and joints smacked in.
Upper frame bracket notched and tacked onto frame just forward of tcase output.
Truss is clamped on. The upper link bracket is tacked to it.
Lower link brackets tacked on.
All links are bolted up.
Today's plan --
Axle side trackbar bracket needs modification.
Trackbar will be shortened.
Put stock Ford steering on.
Ready to cycle the front axle for clearances.
So far main clearance issue is upper link to driver side down pipe....grrrr
Here is earlier pic of upper link frame bracket before link put in and other things.
Old Jul 21, 2014 | 01:05 PM
  #553
merc225hp's Avatar
merc225hp
So as not to pooch this thread I will send you a pm in a day or two. Or pm me your email.
Old Jul 22, 2014 | 09:55 AM
  #554
Wh1t3NuKle's Avatar
Wh1t3NuKle
Picture for upper link is using the top most hole. I moved it down to the bottom hole for more clearance from the exhaust. I thought I got a picture of it.
Ford steering no workie. Drag link about 3-4" too long.
Trimmed up the trackbar 6". Very happy with that piece as it's about 3/8" thick and tons of thread for adjustment. Making drag link and trackbar parallel and the same length mitigates bumpsteer.
Picked up the RuffStuff Y-link Kit.
http://www.ruffstuffspecialties.com/catalog/YLINK.html
Drill out the knuckles now for it to get the steering locked down.
Old Jul 22, 2014 | 01:42 PM
  #555
Wh1t3NuKle's Avatar
Wh1t3NuKle
Old Jul 22, 2014 | 10:45 PM
  #556
tincan57's Avatar
tincan57
Nuk, you must bathe this truck underneath. Nice work. K.
Old Jul 22, 2014 | 11:07 PM
  #557
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Lookin good dude lookin good. You'll be on the road soon.
Old Jul 23, 2014 | 06:18 AM
  #558
TEDD's Avatar
TEDD
Looks real good Nukle, that'll be trick if you could squeeze that link in there without redoing the down pipes. I couldn't. Your gonna love that axle. Will your truss and upper link mount clear that stock x-member? Keep the updates coming!
Old Jul 23, 2014 | 08:14 AM
  #559
Thornloe Pride's Avatar
Thornloe Pride
Lookin good my friend
Old Jul 24, 2014 | 02:00 AM
  #560
Wh1t3NuKle's Avatar
Wh1t3NuKle
hahaha...just no water around here...this year.
fingers crossed
Yes, the xmember is good to go. It's set back far enough to have room upon full bump. Won't know for sure until time to cycle the axle though. That is proof in the pudding, right?
thx
End up replacing the ball joints completely. I was intending to use old ones until they failed. This didn't come to light until the steering had to be done, which requires drilling out the knuckle TRE hole to 7/8" to accept a taper insert that matches the GM 1 ton TRE ends. The factory hole is about 1/2" so that is a bit of metal to remove. So chucked into the drill press. Also had to trim the thickness of the TRE mounting arm from 1" to 0.75" to match the taper insert length, thus the TRE would mount properly.
Need to do this for the pitman arm still.
Get new spindle studs and press in.
Bolt up knuckles.
Ream pitman arm.
Measure for drag link and tie rod from the DOM in the steering kit (1.5"x.25" wall). Cut and tack inserts and mount up.
Fab up the Track bar axle mount. Tack on.
Cycle the axle!
