Wheeling a fullsize
Old 07-27-2014, 04:20 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
Thanks dudes.
Only adds about 20 lbs.
The steering is tight as can be. The steering knuckle still has about 3/16" to .25" before hitting stop. Completely fine for getting around for awhile. I'll be changing the tie rods out for offset ones by RuffStuff. They still have in development the Y-link TRE Offset one, expected release end of summer. Those will give more clearance.
Mocking up shock towers today with some EMT. Have run through alot of brainstorming. We ruled out using the RuffStuff towers due to envelope size too large.
Oh and Ham Bone, forgot a detail about the driveshaft question you had. It will get longer and have more separation from link.
  #572
Old 07-27-2014, 08:12 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Wildman4x4nut is offline
I've got his off-set TRE's for the new tie rod I'm going to build for the Jeep as I need more clearance too. I'd love to have a panhard rod with a bend in it like yours to help me clear my diff. I made mine out of some DOM tubing so it is just a straight piece.
So do I take it you're driving it now since you said the steering is light.
  #573
Old 07-27-2014, 11:21 PM
corbo1962's Avatar
corbo1962
corbo1962 is offline
Wink
Great craftsmenship and great pictures. Makes me think about coilovers on mine. I'm anxious to see the finished beast in action.
  #574
Old 07-28-2014, 12:49 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Hey WM, no not drive-able. Just saying the components are very close to eachother. I've been working on this for about 5 work days. I'm not slow or fast, but alot accomplished in that time.
Did some coilover tower mockup that I'm going to run with. Then moved onto cycling the axle. It looked like I would get full droop from how it's set on the jack stands. Remember, my target is not full rock crawling specs, but perhaps 75%. I'm plenty happy with that.
@HB -- I stand corrected...I did get some DS contact. Driverside at full stuff +. This means it was stuffed way more then where I'll put bumpstops and was with stock driveshaft position. My driveshaft will position will change, which will improve the clearance. Also I can move the upper link up an inch, yet that will likely contact exhaust. There are a couple other things possible to try if need be too. So I'm good for now.
Fits up in there good!
Will reroute the brake line that goes along crossmember.
Full stuff!
Track bar mount on frame side is the bump stop
Next cycle test will be with the shocks...
  #575
Old 07-31-2014, 09:23 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Been real hot, but finished the structural portions of the shock towers. Plan to have them mounted up today, with the shocks.... been 103+ the previous 5 days. Today and tomorrow 106F with poor air quality... bah!!
  #576
Old 07-31-2014, 11:11 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,190 Likes on 2,943 Posts
Holy smokes, that's HOT!
I would be hiding inside, with the a/c cranked up.... I just can deal with that kind of heat. (aggravates my health issues.)
  #577
Old 07-31-2014, 11:20 PM
corbo1962's Avatar
corbo1962
Thats been hotter that here in Hell Paso. I didn't know it got that hot up in northern Cal
  #578
Old 07-31-2014, 11:32 PM
Wildman4x4nut
We have had 102 for 2 days up here in Washington. But I am up in the mountains and we have warmer weather than on the coast.
None is as hot as it was in Iraq plus I'm not packing a 9mil, M16, flack vest, 6 30 round mags for M16, 3 11 round mags for the 9mil, Kevlar helmet & a camel back with 2 liters of water in it. And it was 125-130 out and I walked 2-3 miles in it every 4 hours.
  #579
Old 08-02-2014, 03:14 PM
Johnn123's Avatar
Johnn123
Johnn123 is offline
102F? I wish. I get like 70-80F for summer heat :/
WK, lookin real good man! Can't wait to see the progress on the shock towers and everything! Just awesome
  #580
Old 08-03-2014, 08:13 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I busted some stuff out in the heat. Here are some teasers for now.
Clearances all good.
Fully burned
Quick Reply: Wheeling a fullsize
