bed bolts and lift
bed bolts and lift
i know where my first 2 are. Im trying to figure out where the 2 rear ones go at cause there was not any there when I got it. I also need to know where I can get some rear lift stuff or will pvc pipe do the same as the plastic body lift pieces?
picture for bolts will help (remember my truck is a swb) sorry dumb blonde female here
So you are saying you have a body lift installed on the cab only portion?
Then for the bed, only 2 are installed in the front locations, making the bed tipped backwards?
Any chance you could take some pictures of the whole truck and posting so that we better understand? (better to use a 3rd party photo host like photobucket.com, imageshack.com, flickr.com, etc.)
Look at these links to download a pdf file for Factory Service Manual and Parts Manual. If you want to learn and improve your truck with own mind and hands, then these are great starting places. You'll find directions (for the most part) and pictures.
Service Manual thread
Parts Manual thread
Plenty of people here to lend helping hand and encouragement, but it will be limited by how well you can describe your topic. Use pictures as best as you can. People will expect you to help yourself with the above references, especially b/c most everyone also uses them to help communicate. Lastly, get a Haynes Manual from local parts store.
Edit: Forgot to mention that if you are in fact missing the body lift pucks in the rear, then replacements can be bought online. The parts would come from Performance Accessories. They are the only ones, that I recall, made a body lift for our 2nd gen trucks. They respond to emails and phone calls. Purchasing would mostly be through a store in your local area. They (PA) would tell you best place closest to you.
Got some pictures of mine to help you out. The bed has a total of 3 pucks per side. The pucks have bolts. Then there are 2 bed spacers per side. These are welded to the frame rails.
These pictures show (driver side) the pucks in the rear, near the bumper. The one nearest the bumper is smaller (green box).
Picture of the spacers.
Yioun know your truck is just TOO clean underneath!
Trending Topics
If you're only missing the small one (green) box, then I'd be less concerned.
I have some spare LARGE ones though. I just modified my front mounts such that the puck is gone and have gained ground clearance/approach angle.
Let me know.
