Deep transmission pans...
If the unit has more than, oh, 80,000 miles or so, I'd do a full fluid change, too. It's not too difficult if you've got a five gallon bucket and a helper. More or less like this, but without the intermediate fill with Dexron-III:
If you do that after the internal maintenance but before you put in the remote filter you'll end up with a nice clean load of fluid and a brand new filter that's not asked to trap the crap that was circulating around before the installation.
i've got one of these waiting for me to install.
it also includes gasket, filter, and extension.
its a smidgen cheaper than the hughes.
i wish it included the 8-9 quarts of $6-7/quart fluid it was going to take to fill it up.
http://www.tciauto.com/tc/44rh-48re-...minum-pan.html
http://www.jegs.com/i/TCI/890/128005/10002/-1
I don't know about flush......I would drain, disconnect the cooling lines, and clean out the cooler (there is a can of cooler flush for that), then refill tranny. Maybe do it after a couple thousand miles again.
