99 and earlier brake caliper bolts
Old Jul 22, 2012 | 03:59 PM
Nereaga's Avatar
Nereaga
Default 99 and earlier brake caliper bolts
What size are these things? They are not anywhere close to what my old 01 had, actual bolt heads... 1/4'' allen won't fit and that's the biggest I got, just to gauge size. Is it 3/8''?
Jacked up and all ready to go and then...**** i don't have one of those... Put it all back together... ugh
<---- This is me now!
Old Jul 22, 2012 | 08:15 PM
Nereaga's Avatar
Nereaga
Never mind, just gonna buy a hex socket set tomorrow...
Old Jul 22, 2012 | 08:48 PM
I think they are 3/8ths... might be 10mm..... I just bought a set. I am sure I will do brakes more than once.
Old Jul 23, 2012 | 01:13 PM
zman17's Avatar
zman17
Retired Moderator - RIP
3/8ths on a 98. I just checked a brand new one.
Old Jul 23, 2012 | 04:20 PM
Nereaga's Avatar
Nereaga
Thank You Sir! I will pick up a 3/8''
If I would have been paying attention to the haynes manual, I would have read that they changed the brake calipers from 2000-01. And that they are totally different bolts as well.
Old Jul 23, 2012 | 06:41 PM
Read the manual? How un-manly of you.
Old Jul 24, 2012 | 04:23 PM
zman17's Avatar
zman17
I'm surprised they even mention that.
Old Jul 24, 2012 | 07:08 PM
Nereaga's Avatar
Nereaga
Brakes are done... The manual also mentioned, to make sure to remove some brake fluid from master cylinder, which I forgot to do, and while on the second set of brakes, noticed the master cylinder leaking fluid out... Ugh had to clean it all up, but brakes are fine and I will remove some fluid next time.
Thanks Zman and Hey You!
Old Jul 25, 2012 | 04:51 PM
zman17's Avatar
zman17
Although Im pretty sure you have a 1500, you might want to add that fact to your sig and profile. And I know a 2500 is different, but there might be some helpful info in this thread that applies to both. https://dodgeforum.com/forum/2nd-gen...rake-pads.html
Old Jul 25, 2012 | 05:00 PM
Nereaga's Avatar
Nereaga
Thanks, will do
