2nd Gen Ram Picture thread!!! Pic whore's unite.
#1302
#1303
#1304
Thanks for the correction! I just realized he has a v10 and it's an auto, so it didn't come with a Dana80 rear. Just going off a coworker of mine. Must have really beat the dodge rear axle up to go Chevy. Hope he shares.
#1305
^ Dana 70 HD.
Picked that and the Detroit and the 4.10 up off of Craig's list for like $250, so I figured I should try my best to make it fit.
The 70U under it right now is pretty gruesome (salt water, NE winters, etc.) and has stock gears in the rear. In addition, I want to ditch the factory LSD and put something in that will give me a little bit more capability in the winter, hauling, and in the woods (even though she's a 2x, shes not exactly a pavement queen). I essentially bought the locker (it's brand new, never used) and the axle/gears came with it for free.
I will be upgrading from the 70U 3.5" tubes (IIRC) to the 4" tubes on the 70HD (same tube diameter as an 80 i think).
Guy claimed it was off of a 70's c3500 or k3500 or however Chevy denotes their trucks.
Blanked about the speed sensor,not sure how Im gunna make that work just yet, perhaps an external tone ring?
Will make a build thread when I start getting it together.
#1307
You're using a 180° T-stat?
You're 100K missing on the clock?
If driving mellow, I get that much in 1200 miles... if giving it some, I would get that in 300 miles (using a Moroso catch-can).
I no longer have a plenum issue, and the only oil I add is a half quart every 3 or 4 months (not much more than the catch-can takes out).
#1308
I gotta wonder what that much oil mist means. I don't have to add any oil, but my can definitely catches some.
#1309
Ahhh, I see you came back to edit. I was like...whoa more info! lol
Roger that on the 70U condition.
Some things about the 70HD, which is a great axle btw and should do you fine from what you're throwing at it.
Dodge axles are plagued with the VSS and tone ring. So the carrier has the tone ring bolted to it and then the sensor is in the differential housing pointing at it. It basically provides info for the speedometer and ABS feedback. If you don't care about either (b/c the auto tranny has own speed sensor for shifting purposes) given it's work status, then you may consider ignoring. I haven't tested myself, but perhaps if you can test on yours already by disconnecting the VSS on the harness and see what she does. I recall someone saying around here or elsewhere they just get the ABS light, no CEL.
Dodge 70u axles come with 32 spline axleshafts. Going the Chevy 70HD moves you up to 35 spline bad boys. Why Dodge had to be different here while the other 70s are 35 spline is just another
move.
I have seen builds where ppl take a non-dodge axle and create a spot for the VSS on the housing.
Here is a link to some great info about 70s if you hadn't come across it before.
http://www.pirate4x4.com/forum/chevy...70-thread.html
I've got some other saved threads about possible ways to handle the VSS, however, they are all a decent amount of fab work, including machine shop. If you have that capability and/or interested send me a PM. This is b/c I wanted once upon a time to put in a GM 14 bolt yet still wanted to maintain street use.
![Icon Gunhead](https://dodgeforum.com/forum/images/smilies/icon_gunhead.gif)
^ Dana 70 HD.
#1310
move.
