Trans Rebuild Kit?
Old 01-09-2013, 10:10 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,273 Likes on 3,020 Posts
Looking forward to how you like it once it's all together. I think the stall may be a little high for a tow vehicle though?
  #52
Old 01-09-2013, 10:53 PM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
A LOT high, actually. That thing's going to make loads of heat on grades.
  #53
Old 01-10-2013, 01:04 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
too high.
i'd reconsider something more in an RV style, like 1600
i think stock is around 1800.
  #54
Old 01-10-2013, 01:35 AM
dlyter09's Avatar
dlyter09
dlyter09 is offline
My Mega Viper has a 1600 stall in it
  #55
Old 01-10-2013, 02:31 AM
FireDodge's Avatar
FireDodge
FireDodge is offline
I don't do a lot of towing actually. That's what they recommended when I called them to order it.
  #56
Old 01-10-2013, 10:33 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
That thing got a Hemi in it?
  #57
Old 01-10-2013, 10:36 AM
HeyYou is offline
What DO you use it for? If that was a strip car, I would say 2300 would be about right, but, given it goes behind a 250 horse V-8, in a 5K+ pound truck....... I am thinkin' the guy either wasn't aware of that, or, has never done anything with trucks before.....
  #58
Old 01-10-2013, 11:42 AM
FireDodge's Avatar
FireDodge
Mostly street driving, I do like to beat it up though. It makes trips to the offroad park several times during the year. He said that with cam, that stall speed will give it room to breathe. Also said that when I come up to a river or some muddy trail that if I wanted to just stomp on it or if I did a power brake launch it would be an incredible difference. I thought it was on the high side too, but since I don't know a lot about transmissions and they're a performance transmission shop, I figured he knew what he was talking about.
And with the new motor I was slowly working on, he said with an estimated 300-400 horse motor it would be a great improvement.
  #59
Old 01-10-2013, 12:11 PM
UnregisteredUser
So then you're putting a not-a-truck engine in, so having a not-a-truck torque converter is a good match. It makes a strange sort of sense. Takes the generally utility of a truck away, but if it meets your needs all's good.
Don't show that rig heavy loads, or moderate loads with long grades ahead, or you'll run up against cooling system limits.
Quick Reply: Trans Rebuild Kit?
