building a most fuel economic ram 1500 5.2L
Old Dec 7, 2012 | 11:53 AM
  #31
stocking2's Avatar
stocking2
205 is not too bad, with the stock clutch fan it always at 180 in the temp gauge. also on the concern of transmission , my truck has stock outside transmmision cooler too, so it may not raise the tranny temp. i will put lucas trany fluid to help for increase temp , should solve the problem.
Old Dec 7, 2012 | 12:06 PM
  #32
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by SilverSS
A lot of newer cars run 220*-230*.
A lot of newer cars aren't running small block Magnums. They're already pushing it to run the Magnums at 195, which is the why behind the death flash. (Okay, I'm a heretic. Nothing new here.)
I discussed this with a friend of mine who argued that a name brand gas station is only required to purchase a certain percentage of fuel from the brand they advertised- the rest of it comes from wherever. Any thoughts on that?
Nothing that can be taken to the bank because my experience is from the last century... But once upon a time when I was a field engineer, I used to find myself entirely too often for my liking suited up in Nomex and on one of the many refineries that are/were in California. I serviced equipment at Arco Carson, Mobil Torrance, Chevron El Segundo, Exxon Benicia, and Shell Martinez regularly, and some others sporadically. At those terminals where they had gasoline racks I never saw a company truck at any except the company's lines. There are usually several lines at the racks, with some being company branded and some not, and at some refineries you might see, say, Chevron lines, Texaco lines, and unbranded lines. I never saw independents at the branded lines or branded trucks at the unbranded lines. Doesn't mean it didn't happen -- I never had any business at the racks and only saw them when I would break the rules and go touring around, which is really, really frowned upon. When I got hassled I just pretended to be lost and asked for directions. Some of those security piggers were humorless dudes.
All of this is old information. I'm getting old fast... I haven't set foot on a refinery in a few months over 20 years now. And don't want to, either. Those places are dangerous. Especially when the company wants to shut them down to manipulate prices.
Old Dec 7, 2012 | 12:08 PM
  #33
stocking2's Avatar
stocking2
there are couple reason i don't like the stock cluch fan, noise, drag down horse power, engine always run at thermostat temp., also will give water pump premature failure.
Old Dec 7, 2012 | 12:19 PM
  #34
Gary-L's Avatar
Gary-L
Veteran: Navy
This image properly describes this thread and the logic of the OP.
Old Dec 7, 2012 | 12:42 PM
  #35
SilverSS's Avatar
SilverSS
And in a truck whose engine and transmission are designed to run at 180-195, 205 is kinda warm. Especially for the transmission.
It's always a good idea to run an external cooler on an auto trans. I've never had an auto without one .
Old Dec 7, 2012 | 12:47 PM
  #36
Wombat Ranger's Avatar
Wombat Ranger
Nobody ever challenged you on the idea that using an electric fan will help your fuel economy.
Old Dec 7, 2012 | 01:05 PM
  #37
stocking2's Avatar
stocking2
pictures of works
Attached Thumbnails building a most fuel economic ram 1500 5.2L-qq20121206152637.jpg   building a most fuel economic ram 1500 5.2L-qq20121206152553.jpg   building a most fuel economic ram 1500 5.2L-img1959ap.jpg
Old Dec 7, 2012 | 01:28 PM
  #38
stocking2's Avatar
stocking2
Old Dec 7, 2012 | 01:31 PM
  #39
stocking2's Avatar
stocking2
leak check found is problem with valve
Old Dec 7, 2012 | 01:33 PM
  #40
stocking2's Avatar
stocking2
i change the rings too
