Mopar or Hughes Manifold?
#41
im pretty sure that the manifold isnt going to exceed the length of 73". therefore itll be 7.95.
#44
even better combo..... m1, 52mm tb, custom grind cam by hipotek, custom sct tune, and new heads, and springs, retainers, and locks to handle the new cam. i may add in new lifters and factory length pushrods to the mix too.
gonna be my new combo if i can swing it after we buy a camper.
we're getting about 10k back. so i figure about 1400 for everything i listed. i should be able to do it.
#45
Edit: The 52mm is great above 4500rpm but in the lower rpm range it's not good at all. So if you plan on being over that 4500 go for it.
#47
#48
#49
I have the Hughes Air Gap installed on my rig. I live in Cali (San Francisco Bay Area) and haven't had any issues with my test only smog check. My mods are minimal. SCT, new timing chain and my Air Gap. I had a 52 mm TB installed but the off the line pick up was horrible. Defenitely stick with the stock TB. I got mine from the "parts for sale" section on this site, so I didn't pay retail for it. However, I'd have a really hard time bitting the bullet on that purchase. That's not to say that Air Gap sucks. It gave my rig some *****. I just don't think that the Air Gap or the M1 are worth paying that much.
#50
hipotek recommended a 50mm tb, but because of the cam profile he was offering a 51mm tb would do the trick too. he said 52mm may move my torque curve higher up, and would have not much bottom end. i figured a 52 would flow better, and more air, so id get more power out of it, for towing, and plowing. guess i was wrong.
