redneck_rams 360 build thread
Old Feb 24, 2013 | 10:30 AM
  #171
redneck_ram's Avatar
redneck_ram
Dot to Dot will have number six in firing position. It's just easier to line them up that way. Both at 12 will have number one in firing position.
and thats how its set! im learning fast. this is my first ever engine build, and i think im doing a pretty damn good job!
id definitely like to thank everyone for all the help! especially merc aka mark. i couldnt have done it without all his help!
thanks guys
Old Feb 24, 2013 | 11:40 AM
  #172
merc225hp's Avatar
merc225hp
Thanks bud.
You did a very good job yourself, lot's of good research helped you, you opened the fsm and read it when needed, you called and spoke to retailers. Give yourself a pat on the back for a job well done, not one tabernac was said lol.
Old Feb 24, 2013 | 12:13 PM
  #173
BigRedRam95's Avatar
BigRedRam95
I wish I had the time and know how to put the cam I want in my motor. I was going to go with a 360 short block but cant because my MP computer would not work with the 360. So I am going to just buy a 318 short block and they will install the cam I want if it. When I put the dizzy in I will need to set the fuel right?
Old Feb 24, 2013 | 12:21 PM
  #174
merc225hp's Avatar
merc225hp
See if you can trade your pcm for this MP pcm **P5249546 with someone. Then do the swap to 5.9. do a search for one I found it for $265 new online.
Old Feb 24, 2013 | 12:59 PM
  #175
redneck_ram
Thanks bud.
i actually brought my laptop out with me yesterday so i could read the fsm while putting the motor together so i could make sure all the torque values were correct, and done in the correct sequence.
my buddy kept asking me if i was sure i was doing it right, and hes the guy that comes to me when he needs work done haha.
just cant wait to get it in. however, i think im having transmission issue. having shifting issue from 2-3 hangs up in second sometimes, and i have to let off the throttle to get it to shift. all the trans electronics are brand new as of july, and the fluid looks brand new still. doesnt smell burnt either.
Old Feb 24, 2013 | 05:10 PM
  #176
redneck_ram
how the hell does one get the rear main seal out. i try using a flathead screwdriver, and a hammer to start it, and it wont budge. screwdriver just cuts into the seal. any tips?
i read the pavement sucks DIY thread too...
Old Feb 24, 2013 | 06:33 PM
  #177
dhvaughan's Avatar
dhvaughan
STOP STOP STOP. PUT THE HAMMER AWAY !!!!!
loosen ALL main bearing journals...
rotate engine with crank down.
give it a little push.
pull it through with finger pressure.
the old seal must come out EASILY or you cannot get the new one in.
BE SURE AND TURN THE NEW ONE THE RIGHT WAY. NOTE LIP.
http://www.pavementsucks.com/tech-article-31.html
Old Feb 24, 2013 | 07:22 PM
  #178
dlyter09's Avatar
dlyter09
Everything is looking good man.... Cant wait to see the finished project.. If you were closer I would love to lend you a helping hand.
Old Feb 24, 2013 | 09:09 PM
  #179
redneck_ram
well had a little scare tonight... while out plowing, my son kicked the wires that went to my stobe light bar, and made the +, and - wire connect with each other. this resulted in the + wire completely melting and filling the engine bay, and cab with smoke, because stupid me hadnt put an inline fuse in yet.
it also melted my oil psi line for my mech gauge. im very very thankful that i was parked showing our friends our new puppy.
im extremely nervous now, and i dont know if ill sleep tonight cause im worried that something will catch fire while im sleeping, even though i disconnected everything from the battery.
Old Feb 24, 2013 | 09:16 PM
  #180
redneck_ram
oh, and this ends in about 15 minutes and im the high bidder...
http://www.ebay.com/itm/160976779464...84.m1426.l2649
edit: won it! 212.50 plus 18 shipping.
