redneck_rams 360 build thread
Old Feb 25, 2013 | 09:33 AM
  #181
Originally Posted by redneck_ram
oh, and this ends in about 15 minutes and im the high bidder...
http://www.ebay.com/itm/160976779464...84.m1426.l2649
edit: won it! 212.50 plus 18 shipping.
Good Score! You are gonna like it.
Old Feb 25, 2013 | 11:20 AM
  #182
redneck_ram's Avatar
redneck_ram
i just need to figure out if i can use the 96 thru 00 catridges on my 01, and still do the fuel sync.
Old Feb 25, 2013 | 11:39 AM
  #183
gdstock's Avatar
gdstock
Good deal! My only problem is figuing out what to use all the additional cables on!
Yes. I used mine (with 1999 Catridge) to do fuel synch on a 2001.
Old Feb 25, 2013 | 12:17 PM
  #184
redneck_ram
Originally Posted by gdstock
Good deal! My only problem is figuing out waht to use all the additional cables on!
you sir, are the man!
Old Feb 25, 2013 | 04:58 PM
  #185
redneck_ram
got the rear main seal, oil pump, and pick up tube replaced today.
also welded up my exhaust. welded the o2 bungs in, and welded the cat to the y pipe, as well as a piece of 3" pipe to the back of the cat to connect a muffler to, also where the post cat o2 bung is located.
Old Feb 25, 2013 | 05:02 PM
  #186
stewie01's Avatar
stewie01
So just a question, how's your transmission gonna like the soon to be new found power of a built 360?
Old Feb 25, 2013 | 05:11 PM
  #187
redneck_ram
not sure. its a rebuilt unit, and its taken this years abuse quite well. if it doesnt last, ill nv4500 swap it
Old Feb 25, 2013 | 05:20 PM
  #188
crazzywolfie's Avatar
crazzywolfie
that 3" pipe looks nice. i think your going to be happy with 3" pipe.
Old Feb 25, 2013 | 06:12 PM
  #189
redneck_ram
i thought of going true duals, but decided against it. hopefully it sounds good. slp loudmouth 2 should sound decent.
Old Feb 25, 2013 | 06:29 PM
  #190
crazzywolfie
i think the 1 3" pipe will sound better than 2 2" pipes. i know when time and money allow i want to finish the stock ramcharger exhaust the way it should have come from the factory. with 3"pipe from the y-pipe to the tail pipe instead going from 3" pipe to 2.5" pipe right before the muffler.
